Changing Transaxle Fluid at 134,000 Miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marvinh, May 8, 2017.
  1. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Hello, I know, I have been putting off changing the transaxle fluid on my 2007 gen 2 Prius. And now after reading some other posts, some people say it can loosen the metal particles floating around in the transaxle and cause problems. Can anyone advise me on going ahead and changing the fluid at 134,000 miles?
    Thank you! Marvinh
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    What posts said that? Never heard that on this forum.
    Any loose metallic particles will be picked up by the magnetic drain bolt. Make sure you clean it off. If you think your having gear wear issues
    one trick is to dump the fluid in a wide container and put it in the sun. You will easily see any non ferrous debris floating in the fluid. Ferrous metal will be picked up by the magnet. New fluid will only help its basically a manual gearbox. I've changed mine like 3 times already.
    SFO, M in KC and Raytheeagle like this.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    If you had a normal automatic transmission, then the hydraulic shift logic might possibly suffer from what you mention, in some unlikely scenario. A Prius has no hydraulic shift logic, in part because it never shift gears. (It also tends to be electric where other cars would not)
    If your Prius had these snakey little passages, it is remotely possible a fluid change could block one. It doesn't. Do the change.
    SFO, valde3 and hotelprisoner like this.
  4. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    #4 SFO, May 9, 2017
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  6. tvpierce
    tvpierce Senior Member
    951
    881
    Maine
    2013 Prius v wagon
    It's never a bad idea to change the transaxle fluid. Just do it.
    Mendel Leisk, M in KC and valde3 like this.
  7. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Let me apologize all around.
    It could be time for me to get another eye exam. Somehow I skipped over the part 'it can loosen', which made it read like the OP was asking if they should change the fluid or not.
    Please change the WS fluid, the original owner of my 07 never changed the fluid and the transaxle blew up around 100k.
    #7 SFO, May 9, 2017
  8. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I am proud of you, very few people admit they were wrong on the internet. You are one in a million.
    Raytheeagle likes this.
