Changing Transmission Fluid Without Jack Stand or Ramps?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jbusta, May 13, 2017.
  1. Mendel Leisk
    42,317
    If it's not concrete, I'd recommend some plywood bases, or gauge plate, if you can swing it. Also, maybe a little over-the-top, but I always like to push a chunk of tree stump I have under first, something thicker than my rib cage. And take along a cell phone.
    Fostel, MeMicah, bisco and 1 other person like this.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Talk about unfair, I don't drink beer but I still have the gut. (must be the ice cream.)
    MeMicah and bisco like this.
  3. jbusta
    jbusta Junior Member
    33
    Lastly, does anyone know much adequate clearance is needed (to lift up the prius) to perform most DIY work underneath? Thanks in advance!
  4. Mendel Leisk
    42,317
    I did a little measuring: the front bearing point I use is roughly 6.5" off the slab, when the car's down. The 6 ton safety stands I typically put in at that point have a cradle height roughly 15". So, a lift of 8.5". Now, that is generous clearance, more than enough. Maybe around 6" lift would be a decent mininum lift?
    What are most ramps btw, 8"?
    jbusta likes this.
  5. jbusta
    33
    Exactly what I was looking for, mate! Thank you tons!
  6. DivideByZer0
    DivideByZer0 Member
    67
    91
    San Francisco, CA
    I tried this method a few minutes ago and it worked great! No problems at all
    Fostel likes this.
  7. KeystoneKid
    KeystoneKid Junior Member
    24
    Utah
    Regarding lift, has anyone of you homebrewed the 2 x 4 wheel cribs you see videos about on YouTube? They appear a little weak to me but guys swear by them. I think I prefer the ramps in the front and jack stands in the back? Fear drove me to it! LOL
