Charge Control
Discussion in 'Gen 3 Prius Technical Discussion' started by warby99, Jan 28, 2019.
  1. warby99
    warby99 Junior Member
    Liverpool England
    Business Edition
    Can anyone tell me what a Charge Control sayin -25KW means. I am using the torque Pro app and I am not sure what this is the Aux Battery is showing 14.4. v and al the 14 pods are showing 15.9 v Anyone got any idea Cheers
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I'm guessing this is the HV battery charge, not the 12V. There is a limit to how much energy the HV battery can take, depending on its charge and temperature.
  3. warby99
    Liverpool England
    Business Edition
    Hello thank you for your reply The HV Charge control is for the 201 volt battery but I need to know why the charge control is showing minus 25KV, is this normal or is there a fault
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I don't use Torque Pro, but it sounds like you're measuring power into and out of the traction battery. It goes both ways and one is positive while the other is negative.
    If there's a fault, you'll get lights on the dashboard.
  5. Maarten28
    415
    224
    Netherlands
    I assume it's the charge control limit and there is a charge and discharge limit. One is positive, the other is negative.
  6. ChapmanF
    19,020
    Big difference between 25 KW and 25 KV ! I think you had it right the first time.
    A limit of −25 KW (that is, 25,000 watts into the battery) would mean limiting the charging rate to less than 125 amps (in practice, I've mostly seen rates under 100).
    25,000 volts into a 201.6 volt battery would be somewhat unreasonable.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    But it WOULD be exciting!! :ROFLMAO:
    RMB likes this.
  8. warby99
    Liverpool England
    Business Edition
    Yes it's KW but still had no real answers as to what it should read when normal
  9. ChapmanF
    19,020
    -25 KW sounds about right, about 125 amps of charge, I don't think I've ever seen it go above that.
    Did you have a reason for concern?
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No "normal" value for KW regen. It varies while coasting, cold soak start up, brake pedal pressure & etc.
    Raytheeagle likes this.
  11. ChapmanF
    19,020
    The gen 3 repair manual does state a "normal" value for the charge control limit, namely "−33 kW or more".
    The minus sign is because Toyota considers power from the battery to be positive, so power to the battery is negative. And they mean "or more" in the math-geeky way where the + direction on the number line is 'more', so, you know, −25 is 'more' than −33, and zero is 'more' than either.
    In other words, they're saying −33 kW is the strongest regen you might ever see. As the battery gets charged or cold/hot or tired, that number will adjust closer to zero and the regen will be less strong.
