Charge long or often?
Discussion in 'Prime Plug-in Charging' started by MNdriver, Aug 15, 2017.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    What is maximum cold soak? I only because I rarely ever use the timer. What's the advantage of it?
  2. 4rpr15
    1,056
    375
    WI
    I plug mine in at midnight and disconnect it at 6am. Should I turn on the heater prior to driving the vehicle when it's freezing cold? And if so for how long?
    Michael Wood likes this.
  3. Tideland Prius
    16,680
    Depends. Do you like a warm interior before you head out? :p
    Yeah I'd probably do it. It's a bonus feature of plug-in vehicles (most BEVs and PHEVs have a pre-climate function) so you might as well use it and get into a warm interior prior to heading out. The car will turn on the heater automatically but I'd probably set the "Departure" time as close to your actual departure time to ensure the interior stays warm and doesn't cool down. However, if it's plugged in, the car will turn on the battery heater as necessary so even if you don't do pre-climate, the battery should temperature should be moderated.
  4. 4rpr15
    1,056
    375
    WI
    I have seat heaters so it really doesn't have to be warm right when I sit inside. :)
  5. MNdriver
    MNdriver Senior Member
    549
    577
    I've been contemplating the same question as we get closer to Minnesota winters.
    I park in my condo garage. When it's 5 outside it might be, maybe, 55 inside. With the heated seats and steering wheel, I won't need it pre-heated for my comfort. But would there be any benefit to the car to pre-heat it before I leave for work?
  6. Tideland Prius
    16,680
    Then I guess we have an answer?
    I'm thinking the battery will warm up once you start driving so really it's the performance of the first.... I don't know ... 1-2 minutes until the battery warms up. But again, if the car was left plugged in, the battery warmer should've been turned on.
    Michael Wood and 4rpr15 like this.
  7. 4rpr15
    1,056
    375
    WI
    Does the battery warmer turn on automatically in cold conditions?
  8. Tideland Prius
    16,680
    Yes if the car is plugged in. Page 126. Note it will respect the charging timer settings.
    The idea is that at temperatures below freezing, it will attempt to bring the battery temperature up to freezing point. I assume it has its limits (so a cold soak at -20°F may cause it trouble to bring it up to freezing, for example. I don't know the exact numbers but I'm just giving an educated guess)
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's when you allow the battery-pack to rest as long as possible before the recharge begins. It's for longevity.
    Toyota conveniently gives you the scheduling feature to make that easy. I have mine set on weekdays for charging to complete by 7 AM in the morning and 4 PM in the afternoon. That makes the process basically brainless. You just plug in and let the car figure out when to start charging and pre-conditioning. To override the schedule, just click the "Charge Now" button when powering down.
    It's a simple way to get the most out of your investment. Coming out to a car that's warmed or cooled for your departure is rewarding in itself. Knowing it's also taking steps to extend the life of the battery-pack is a great bonus.
    For those of you who decide to take advantage of time-of-use discounts from your electricity provider, it requires setting the schedule anyway. So, why not?
    Michael Wood and Prodigyplace like this.
  10. Dm84
    Dm84 Member
    60
    38
    MA
    Because if you come home with a dead battery and have to run an errand an hour later it could mean the difference between driving on battery or burning gas. Yes, you can override but that's a pain to remember.
  11. john1701a
    12,840
    5,312
    58
    Pressing CHARGE NOW when shutting down or hitting the button later when plugging in becomes trivial after you've done it a few times.
    #31 john1701a, Oct 4, 2017
  12. David D
    David D New Member
    Connecticut
    I just purchased the Prime Premium. The service manager at the dealership in CT told me the car will not start - period - if it has not been plugged in after 3 days. I am more than skeptical. Thanks.
  13. markabele
    5,084
    1,782
    Nebraska
    Haha, omg. This guy should be fired on the spot for a comment like that.
    you could, in theory, never ever plug it in and be just fine
  14. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    Quick Question - on days when I only have about 10 miles of EV driving to do, what do you guys think of this idea? If I have a 9:30am departure time, I could set the charge timer to finish the charge at 10:30am. Then unplug early at 9:30am and leave with a 70% charge approx. This way I only take as much EV power as I need (approximately) and bring the car back drained.
    Any downside to this?
    phlack and Tideland Prius like this.
  15. Tideland Prius
    16,680
    Not that I can think of.
  16. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    It would work. The only thing would be if you decide to drive longer or need to use a lot of heat or AC, and you run out the battery charge, you will be burning more gas.
  17. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    I unplugged this morning an hour early as planned. On the dash, only 1 of the 3 lights was fully green, while the middle light was blinking. Pulled out of the garage and the car said I have 30.7 miles available on EV. I was impressed.
    I need to test this by doing a full charge tonight and see what the reading is. I haven't been paying much attention to this until now. It will be interesting to track any fall-off in capacity over time - I'm sure temp will play a role too.
    My 2015 NiMH battery still feels like new with 135k miles. I don't notice any difference since the day I bought it. I expect that by 2023-2025 I'll be noticing some degradation.
    #37 Michael Wood, Oct 1, 2020
  18. Salamander_King
    11,024
    8,978
    New England
    You might want to switch the HSI EV gauge to % instead of miles. That way you have both EV range in miles which can be seen on the left corner of the dash by toggling the trip button on the steering wheel as well as % of battery remaining. See the photo below. With an L1 EVSE, the last 1 hour of charge is tapered and slowed down. Also, the charge usually finishes earlier than the time set on the schedule. In my experience, as early as 30min before the scheduled departure time. So if you unplugged the charge cord 1 hour before the scheduled finish time, you might have had only 30 min of charging remaining for the slow finish up. Thus the SoC (State of Charge) of the traction battery at the time you unplugged might have been over 90% full.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Ditto. I like having both miles and % available. And I've unplugged with 20 minutes left on L2 and seen it at about 99-100%. If you have your EVSE plugged into a meter, you can see the current drop as the battery gets close to fully charged. That's part of the battery protection logic.
    Michael Wood and Salamander_King like this.
  20. Tideland Prius
    16,680
    Yup. It finishes about 30 mins prior and the 30 minutes remaining (if you opened the door and looked at the MID before you unplugged the car) meant you were close to 90%. I find that 2 solid dots with the 3rd dot blinking only occurs really close to fully charge. The majority of the time, it's 1 dot with 1 blinking dot. (if it's 1 dot blinking, I think that's something like <10%?). The manual is really vague on this.
