"Charge Now" unable to select
Discussion in 'Prime Main Forum (2017-2022)' started by btrflies, Dec 18, 2017.
  1. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    On ours sometimes the plug needs one more little push to get it fully engaged. The plug moves in a fraction, it clicks, and the green light illuminates. The power supply gives its clickclick-click and its green light illuminates.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Plugged in the J1772 plug, green light lit up, the three blue lights on the dashboard not lit or flashing opened driver side door then closed it, got the famous charge now message with it greyed out and no response from the steering wheel joystick, turned on car and observed the charging connector icon, there was no activity there, then after a few seconds the charging receptacle icon started charging and the far right hand side blue light started flashing
  3. priuscatprimeguy
    2,730
    2,640
  4. priuscatprimeguy
    2,730
    2,640
  5. priuscatprimeguy
    2,730
    2,640
    For some reason I have taken a picture of the charging station and the picture fails to show up
  6. priuscatprimeguy
    2,730
    2,640
  7. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    priuscatprimeguy likes this.
  8. priuscatprimeguy
    2,730
    2,640
    Which God?
    MNdriver likes this.
  9. p74atrick
    p74atrick Junior Member
    17
    ESYR, NY
    Polaroidus.
    #29 p74atrick, Aug 25, 2018
  10. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    I had this happen just last week and after playing with it, disconnecting, reconnecting, etc. it started to charge on its own. This was on a 240v charger at our local college, not my 120v at home unit. I've only had it once but try Huskers suggestion.
  11. priuscatprimeguy
    2,730
    2,640
    Ok, I had it happen so I timed it, three minutes till it starts charging
  12. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    just saw this today, was strange. i tried locking the whole car with my fob, and i think it started to charge immediately. i think...
    next time i'll just leave it and do nothing and see how long it takes to start charging.
    weird thing was at the beginning, no blue lights on the passenger dash board, then after some fiddling around, opening doors, trying to press steering wheel buttons, etc
    i noticed 1 blue light on , but solid.
    eventually after the locking trick, (if thats what did it) the single blue light was flashing like normal charging, and if i opened a door it said on the MID 5 hours 30 minutes to full charge.
  13. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    Occasionally there will be a delay before charging starts. Possibly related to the battery having been heavily used just prior to starting charging (unproven at this time?).
    This morning, I plugged into the same L2 charger I always use and while the "Charge" light activated on the L2 charger, nothing happened on the Prime side (i.e. no charge lights on the dash - although I heard the low "hissing" sound the vehicle makes while charging). After about 3-5 minutes, I heard the sound of a relay tripping coming from the rear and the vehicle finally started charging.
  14. menloli
    menloli New Member
    silicon valley
    2020 Prius Prime
    Sounds like it's a software problem that they haven't bothered to fix. I have a 2020 Prius Prime and I have encountered the same problem half a dozen times over 18 months,that's why I go on the web to find a solution. Typically happened when the battery was not showing 0%. It eventually would start charging after a few minutes,but at a public charging station I had to hang around to be sure it's started.
