Charge Won't Shut Off in Cold
Discussion in 'Prime Plug-in Charging' started by Jim66, Feb 9, 2021.
  1. Jim66
    Jim66 Junior Member
    Wisconsin
    2018 Prius Prime
    Have 2016 Prius Prime. When temperature gets below 10 degrees, green charge light by plug in receptacle does not go off even after green dashboard lights show a full charge. Light on charging station (240 v) still shows "charge in process" status. Consistent problem during periods of "Polar Vortex" with nighttime lows below zero. Is the charging station still drawing current when battery is 100% charged if input receptacle's green light remains on? Will this go away once weather warms?
  2. Tideland Prius
    16,672
    It’s probably keeping the battery warm.
    jerrymildred likes this.
  3. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    mine does the same thing..
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    <Trumpet fanfare > :) The owner's manual says:
    Tideland Prius likes this.
