Chargepoint Usage, people?
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, May 17, 2017.
  1. MartyPrime
    MartyPrime Junior Member
    50
    86
    Los Angeles
    I would definitely check around the Santa Monica location that is listed on your map. I know for a few of the charge point spots on my map, it took me a few times to actually find the station itself. and then once you find it, you can mark it down with a heart and label it the way you want, so you can remember where it is. I don't go out of my way to charge my car, but if it's convenient then i use the charge point. Even if you just charge it for an hour it adds some extra range.
    HPrimeAdvanced likes this.
  2. Jordango
    Jordango Junior Member
    Huntington Beach, CA
    Steve: Pacific City in Huntington Beach has four Chargepoint stations. We went there the other night with our friend's BMW I-3. It cost them $1 per hour to charge. For me, there is a Blink station about 2 miles from my office, but I don't see the point. It takes too long to charge and i'm not going to sit and wait for my car. And Blink costs $.49 per hour. So there's no savings. I wish there were more stations. We are all early adopters here. The market hasn't taken hold yet. Eventually, fast DC charging will be as ubiquitous as gas stations. -
    HPrimeAdvanced and stevepea like this.
  3. stevepea
    stevepea Senior Member
    535
    581
    Actually I believe the location IS there -- a friend found it using an app and showed me a picture someone posted of what it looks like. But it's not technically at the address/strip mall. Instead, it's actually just a parking spot along Santa Monica Blvd -- as if parking along Santa Monica Blvd isn't hard enough to find, the one spot where there's a free chargepoint charge will no doubt be occupied all the time. Still, at least it's technically there...
  4. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    ChargePoint purchased GE EV charging network. Adding 1800 more commercial stations.
  5. ArcPrime
    201
    166
    Arcadia, California
  6. markabele
    5,084
    1,782
    Nebraska
    Are they fairly evenly spread out or are they concentrated in one area of the US?
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
  8. markabele
    5,084
    1,782
    Nebraska
    Thanks! Where did you find that map? I'd like to zoom in and see how it affects me personally.
  9. Lee Jay
    5,850
    4,036
    plugshare.com
    Use the filters.
    Old Bear likes this.
  10. ArcPrime
    201
    166
    Arcadia, California
    Plugin at ChargePoint point station at work this morning as usual. Weird thing happened, after 10 minutes of 3.15 KW per hour charge it started to ramp down till 0 KW and stay there for 25 minutes. I went back to my car dashboard blue charging indicator light is on. ChargePoint power stayed at 0 KW. I check my A/C was not on. I had to unplug the ChargePoint power cord and restarted the charging process. Car shows 2 hour 10 minutes to full charge.
  11. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I used $0.99 of my chargepoint $100, that was a parking fee for using the charger at one place. I used about 20 different chargepoint locations during the 3 month period but all of them were free except the one that had a connect charge but not a usage charge. I also bought a ChargePoint for home but have yet to get it installed as I haven't had time to deal with an electrician.
  12. ArcPrime
    201
    166
    Arcadia, California
    Got my June ChargePoint Summary: $25 , 94 KWH energy added (26.5 cents per KWH due to inefficient of extra time hooked up to the station and charger rams down) distance added 236 miles estimated. According to my own calculation <4.3 miles per KWH so 404 miles instead of 236 miles from ChargePoint calculation.
    So added 404 miles/55 mpg=7.35 gals
    $2.79 x 7.35= $20.50
    I get better than 55 MPG ,
    paying less than $2.79 per gal of gas.
    It's not economical justified to continue using ChargePoint. However it makes sense to charge at home. If home charge won't move me into SCE tier 2 price (14 cents vs 23 cents) per KWH.
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    ChargePoint underestimates miles added.
    18 actual for me is reported as just 10 estimated.
    ArcPrime likes this.
  14. Lee Jay
    5,850
    4,036
    I got my June summary:
    $0
    1kWh
    3 miles
  15. 175
    175 Junior Member
    Rives, TN
    $100 ChargePoint card available. Expires 8/31/17.
  16. bisco
    52,773
    how much?
  17. 175
    175 Junior Member
    Rives, TN
    $50
  18. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Hey, mine is only $1.00; if course it expired in March!
    ArcPrime and bisco like this.
  19. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    Mine expired in June with $98 still available on it.
    Here on the left coast my math determined that So Oregon electricity(0.075) at home is about 1/4 the cost per mile vs gasoline, and Sacramento(0.11) electricity at home is about 1/2 the cost per mile vs gasoline. The only Chargepoint that I used the card on worked out to about $3/gal equivalent. When gas goes above $3, I will consider them again.
