Charger Cable and 220V?
Discussion in 'Prime Plug-in Charging' started by stevepea, Jun 23, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    At home I only have 110V, and use the included Toyota charging cable.
    But how do you charge at someone else's house (not Chargepoint) if they have a 220V outlet for their electric dryer? A relative has a 220V outlet (for his dryer), but I can't plug the included Toyota charger into the wall because the holes are different in a 220 outlet than a 110.
    Does that mean I can never charge there at 220V (unless he gets some sort of charging station -- which I would never ask him to do for just me coming over occasionally). Or is there a way people can directly plug into a 220V outlet (say, one used normally for an electric dryer). An adapter for the 110V charger cable, perhaps? A 220V version of the charger cable?
    For someone who has a 220V outlet (for things like an electric dryer), is there any way you could simply plug into that outlet, or must some sort of charging station have to be installed?
    52,776
    not with the supplied cable. you can buy a 220v evse, or get yours upgraded to 110/220 at evseupgrade.com.
    TGrracie, stevepea and alexcue like this.
  3. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    The electronics on the Toyota charging cord can't handle 240 volts. Stick with your 120 volts. Or do the upgrades bisco mentions--but are they worth the money???
    Adapters for charging cables only change the plug configuration. There are a couple of differently configured 120 v plugs and several different 240 volt plugs. No adapter can change the voltage (and, we're not getting into transformers here nor splitting the hot leads, folks).
    The U.S. upgraded household power to 120 volts and 240 volts sometime in the 1950's.
    TGrracie and Valiant V like this.
  4. JoePriusPrime
    JoePriusPrime Member
    46
    35
    Denver, CO
    I'm thinking about buying one of these since I have a 220v in my garage:
    ChargePoint Plug-in Station with 25' cord $674
    or I've heard good things about ClipperCreek $395
    ClipperCreek LCS-20P (I like the portability of this one)
    #4 JoePriusPrime, Jun 23, 2017
    PriusByrds likes this.
  5. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    We just purchased 2 of the Wi-Fi Juicebox chargers.
    Love'm.
  6. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I like the reviews on them also, but they aren't UL listed or ETL listed yet. I need them to be "listed" so I can qualify for the $500 utility credit. I have the JuicePlug of theirs.
  7. john1701a
    12,840
    5,312
    58
    They've been working toward the certification. The recent switch to the new box with the short cord will hopefully get the listing.
  8. stevepea
    535
    581
    Thanks for the replies and the options, everyone. Would've been nice if Toyota included both a 110 and 220 charger, but oh well. For the costs involved, I won't bother getting a 220 charger (since it would only be an occasional charge at someone else's place), but if I did, I'd probably lean towards the Clipper Creek. Looks simple, straightforward, and price is (relatively) reasonable -- $379.
  9. CharlesH
    2,798
    1,166
    Roseville, CA
    Just emphasizing the point: If one used an adapter to feed 240V to the Toyota EVSE, one would likely have their own private fireworks show. Home electrical systems for our friends in the UK and the rest of Europe are 240V, so the EVSE provided to them supports 240V.
    Singh Saab and Valiant V like this.
  10. bisco
    52,776
    doesn't your relative have an accessible 110 outlet?
  11. Rainydave
    Rainydave New Member
    Glendale, CA
    2018 Prius Prime
    New owner - what does EVSE stand for. Thanks
  12. Tideland Prius
    16,670
    Electric Vehicle Supply Equipment.
    Basically the object that supplies electricity to your car. It’s the one everyone calls a charger or charging station (but technically, the charger is built into the car).
    priuscatprimeguy likes this.
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    So what is the difference between a charging station and an EVSE? Or is a charging station just an EVSE on steroids, including things beyond the basic EVSE functions, such as usage logging and Internet access and, for public charging stations, billing?
  14. Tideland Prius
    16,670
    The technical term for the "charging station" is EVSE since for the most part, they only supply electricity to the car. The car's onboard converter will limit the supply (amperage) and deal with the nitty gritty stuff. This is why, technically, the charger is in the car and that's why the stuff you mount on the wall or the "public charging stations" or the cable you carry is all part of the EV Supply Equipment.
    However, the general public has taken on the term "charging station" or "charger" as the equipment that supplies the electricity.
    So.... in general chitchat, it's interchangeable.
    (just like the wall outlet is technically a receptacle and the charging cable end is the plug).
  15. CharlesH
    2,798
    1,166
    Roseville, CA
    I knew about the charger being in the car, at least for AC charging. For DC fast charging, isn't the external device the actual charger? I was just wondering if there is any technical distinction between a charging station and an EVSE. Or are they the same thing.
  16. Tideland Prius
    16,670
    Yeah in a DCFC, the charger is located in the unit itself.
    It's not a technical distinction but more of a misnomer.
    While not a great example, it's like asking if Kleenex and tissue paper has a technical distinction. No they don't. The "technical" name is tissue.
  17. Rajiv Anand
    Rajiv Anand New Member
    PA
    can I plug a prius prime 110v charger into 240 volts
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    RandyPete likes this.
  19. Rajiv Anand
    PA
  20. Kemcho
    Kemcho Junior Member
    Fairfield ct. 06824
    Hello I was using special cable that I bought $269 when I got my new 2017 Prius prime adv and that cable has different type of plug
    so the electrical works install for me at my garage it cost me $50 + 10 material and I use the special cable to charge my Prius prime adv
    and it get charge in less the 2 hours and I did use that for 3 years and no problems and now I sold my Prius but I did not sell the cable
    I have that cable and I selling that cable $ 190 + shipping so if any one looking for 220v charging cable for Prius please let me know
    and I do have the original Prius charging cable also that comes when you buy
    #20 Kemcho, Apr 27, 2021
