Charger O ring
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DonJa, Feb 6, 2017.
Tags:
  1. DonJa
    DonJa Junior Member
    Montana
    2013 Prius Plug-in
    The orange O-ring in the base of my 2013 charger is starting to look like a mobius strip, i.e. all crinkled and twisted. And at times makes it very hard to get the final click in the connection. I am assuming I should just pull it out because---
    I saw in the Can't Disconnect charger thread that Bisco said: "if the o ring has dislodged, remove and discard."
    My Question: if I pull it out, do I need to be particularly concerned about rain or snow melt (common in MT) getting into the charger??
  2. mrbigh
    3,686
    699
    Long Island, NY
    If you do not poor water with a hose on it while connected, won't matter
    Pluggo likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Agreed, pull it out. You don't need it.
    retired4999 likes this.
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yes! just discard!
    Charge as usual.
