Charging 12 volt battery
Discussion in 'Generation 1 Prius Discussion' started by Dirt Digger, May 10, 2015.
  1. Dirt Digger
    Dirt Digger Junior Member
    Rochester ny
    Is it ok to charge the 12 volt battery with a 15 volt battery? My car sat for four months and needed to be charged which i did with a portable 3 in 1 (charger, compressor, work light) charger. It charged and ran normally for five days. After that, when i turned the car off the dashboard light stayed on and flickered crazily. Thanks for any insights.
  2. Mirza Murtaza
    Mirza Murtaza Junior Member
    Some questions to know:
    How old is your car's battery ? If its life exhausted then must be replaced.
    Is the Battery Charging System in your car working properly ? If system is not working as per its rated out put, then repair or replacement is required.
  3. Patrick Wong
    18,214
    6,531
    The maximum voltage that should be used to charge a 12V AGM battery is 14.4V. Once the battery has been charged, if it fails to hold the charge over a reasonable period of time, then it needs to be replaced.
    The 14.4V charging voltage should be stopped when the charging current no longer drops as time passes. If desired, a trickle charge to maintain the battery charge can be applied at ~13.2V.
    Measure the voltage across the 12V battery when the Prius is IG-OFF. A new, fully-charged 12V AGM battery will measure ~13.0V. If the voltage measurement is ~12.0V, the battery is near-discharged. An intermediate measurement value will show you the approximate % charge - for example, 12.5V would be ~50% charged.
    Then, measure the voltage across the 12V battery when the Prius is READY. The voltage should measure ~13.8V which would indicate the DC/DC converter is working OK. If much lower, the 100A DC/DC fusible link has blown or the converter has failed which means the inverter needs to be replaced.
    #3 Patrick Wong, May 10, 2015
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Didn't you already ask this question in another thread ??
    Where do you get a 15 volt battery and why is that part of the question ?
