Charging 12V step change - 14.0 to 13.5 volts.
Discussion in 'Gen 2 Prius Technical Discussion' started by uart, Jan 14, 2011.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    This is getting "interesting". Here are the theories I gathered so far:
    1. The charging voltage drops when the (good) 12V battery is fully charged
    2. It's a bug
    3. The charging voltage drops due to excessive load from a bad battery
    4. Bad connection causing poor regulation
    But none of them explains all observations:
    1. Why doesn't Patrick see the drop in his two cars with good batteries? Why does koolingit see it with his marginal battery?
    2. It's just hard to imagine Toyota engineers would miss this for so many years.
    3. Why do some people only see the drop after changing to a new 12V battery?
    4. Why would it depend on the shift position?
    It's a good puzzle. I am leaning toward #4 now but not 100% sure. Once koolingit have his battery changed hopefully we will get some more data. Still pondering...
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi David. This is the inverter bus voltage we are talking about (ready mode) so a high resistance battery connection would NOT cause this. If anything it would have the opposite effect. A very low resistance and a partially shorted battery could drag the bus voltage down, but I assure you that this is not the case.
    Lets look at this logically.
    - This voltage drop has now been reported by at least six different owners (probably more).
    - Some noticed it after installing new batteries.
    - It is NOT random but happens (or not happens) under very specific circumstances. (Read software implementation not random bad connection!)
    - It is a very abrupt step change, not the gradual or incremental sort of voltage drop that you see due to battery loading.
    - It happens when the electrical system is lightly loaded (not when heavily loaded).
    - It drops the voltage by exactly the correct amount to put the battery into "charge maintenance mode". Where the existing battery charge is maintained but negligible further charging is applied. As I said in a previous post I can find numerous sources that indicate that a voltage of around 13.4 volts is ideal for this purpose.
    - It generally happens after the car has been operating for some time with low electrical loading (exactly when you'd expect the 12V battery to perhaps be fully charged already).
    - At least one other user has indicated that this happens on a newer model prius (08) but not on his older model (07) so it may be related to a software update. Perhaps that's why not everyone has seen it. Also since you probably need to have the 12v battery in a good state of charge and drive for some time with minimal electrical loading to see it then that's another reason why many people might never see it.
    There are two main things that drastically shorten the life of a battery. One is overly discharging the battery and the other is excessively charging the battery. Consider a Prius that spends a very large amount of time in ready mode, say a taxi running multiple shifts for example. While 13.9 to 14 volts is not enough to serious overcharge a battery in a short to medium period of time, if maintained on the battery all the time then you would eventually overcharge it somewhat. The drop to 13.4 to 13.5 could easily have been a software implementation to address this.
  3. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Just read the posts since my last post. When I ran my test I connected my voltmeter directly across the battery and ran the RS232 output of the voltmeter to an RS232/USB converter then a USB cable to the netbook where I recorded the voltage sampled every two seconds. My graph was done in Excel from the recorded data. There is definitely a step voltage change when the AC is cycled on and off, and the same value step occurs at other times. In my graph where the voltage is changing levels rapidly is where I was turning the AC on and off. I didn't try to figure out any other causes. I performed my test as a curiosity since I had seen the same two distinct levels on my scanguage.
    Uart you make a good observation vis a vis model years. Mine is an 08 and yours and others have 09's while Patrick has an 07. Currently I have about 25K on the car and the battery has never failed to start or been disconnected since the car was new. And I live in a super mild climate and the car is always garaged.
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    No mine is only a 05 model that was purchased S/H from a Toyota dealer in 09. I don't even know if my 12V battery is original or not. Mine is an Australia model and there are some differences in features etc between models from different region so perhaps this is one. Also I suppose it's possible that the dealer applied a software update.
    I think more people need to test this out so we can get more data. When people get some good weather if they can take a trip without A/C or blower and with MFD in signal check mode and see if they notice it. I think if more people try this then we'll find a lot more people observe it.
  5. direstraits71
    367
    65
    Sorry my error on your car's year. As you point out, yours is a non North American car so that might make a difference. I was curious at what scanguage was showing so I made sure I didn't rely on anything the car was telling me about the voltage. By using a completely isolated set of test instrumentation and my setup was totally powered by the DMM battery and the netbook battery not connected to the car except two wires directly from the battery. This assured me that the voltage across the battery itself was truly varying as I had seen on the Scanguage II.
  6. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    All I can add is that on a 70 mile drive yesterday SGII was showing 13.8-13.9VLT the whole time. It was so boring I changed it to LOD.
    - D
  7. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    This is interesting, they have apparently implemented a 2-stage charging algorithm. Strange that they went to that trouble, but neglected to temperature-compensate it. In the winter the 12v battery never gets a full charge for this reason.
  8. northwichita
    481
    102
    29
    Wichita KS
    I have seen the low 13.5 voltage on my 04 with the original battery when driving on the second trip of the day (which is about 1 hour from the first), so perhaps starting the car with the battery being fully or at least recently charged has some relevance. The other conditions uart mentioned, -no other electrical loads- also apply, the second I turn on the fan the voltage is around 13.9, 14.0. .
  9. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    For the record: I haven't seen the voltage drop to 13.4 in the cold months. It was 50 degrees today and the scanguage stayed at 14 volts all the time.
  10. GranDad
    GranDad Junior Member
    Australia
    Hi and hello to all from downunder.
    First post but I have been sandbagging on the side for quite a while.
    I have an Australian white Prius built April 2008 with 130,000 Km on the clock. We are lucky in Auz as our cars come with no bladder or thermos and we get EV and rear discs along with adjustable driver’s seat as standard.
    After following this thread I decided to reproduce uart's configuration. It has bothered me that Toyota would leave the auxiliary battery continually sitting around 13.8-14.00v. I personally find this too high for extended periods and thought that if Toyota could put such a stellar effort into maintaining the SOC of the HV battery then looking after the little battery would be a piece of cake. The amount of software for controlling this last stage of charge would be minimal.
    I first off placed the car in accessory mode to read the initial state of charge by going into maintenance mode; it was 12.5V this was after sitting for four days. I then switched to IGG ON and tuned the AC off and the fan off. I then went back to Accessory mode and placed the display in maintenance mode again, by this time the voltage was reading 12.3V. As soon as the car was made ready the voltage rose to 13.9V for a few seconds then stabilized on 13.8V.
    I live in the northern part of New South Wales and my trip was to the local supermarket which is about half an hours’ drive. Leaving the maintenance screen up and all accessories off the voltage stayed constantly on 13.8V while driving with the occasional blip to 13.7V. At around the 25th minute into the trip the voltage immediately dropped to 13.2V and just sat there. After some time I turned the AC on by using the steering wheel switch, this caused the voltage to rise back to 13.8V until I shut down. On the way home I repeated the test and at around the 22nd minute it did the same.
    This is not a bug, it is a feature and I am glad my battery is being looked after properly. I think that these results will be confirmed by all who repeat this test as detailed providing your battery is in a good state of charge (and condition) at the start of the test.
    I hope that what I have witnessed will be helpful to others
    Cheers GranDad.
    2 people like this.
  11. direstraits71
    367
    65
    If you look at my graph in post #2 I recorded the same behavior upon startup. Looks like there's a feature that requires the full charge voltage for 20 or so minutes after start along with forcing the full charge voltage with the fan being turned on. I agree its a feature not a bug!
    I don't think we've heard from any one with a North American version 2004-2006 that has seen this? Anyone with a scanguage can observe if there are two distinct voltages and can try observing as the fan is turned on and off.
  12. GranDad
    Australia
    I really don’t think it is a function of the fan or the air conditioner. I think it is just because a load is placed on the system and the battery is being taken off float. Next time I will just turn the lights on and see what happens.
    Cheers GranDad.
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks GranDad, that really closely follows what myself and Direstraits71 have observed. I think we can pretty much say case closed on this not being anything abnormal. :)
    Ok that adds a new light to this, thanks for the info guys. As pEEf points out you need more voltage to fully charge the battery at low temperatures and conversely you can overcharge and gas a battery more easily and at lower voltages when the temperature is high. So it looks like this is a high temperature modification to the battery charge algorithm. If this behavior only kicks-in above some preset temperature then no wonder most people in the USA aren't noticing this at the moment.
  14. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    Hi GranDad,
    Thanks for weighing in with your observations but I don't agree it's a feature.
    If it is a feature, it's kind of lame. In order not to overcharge the 12 volt battery, you have to keep the AC turned off (not even the fan is allowed). If the AC is off and you turn on other loads, the voltage will sag further.
    Most people will have the AC on in the hot weather. A lot of us will have just the fan on in spring and fall just to keep fresh air moving through the cabin. So, most times this 'feature' doesn't work!
  15. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    I haven't seen it mentioned here but if you're reluctant to put the MFD in maintainance mode because you have to shut down the car to get out of it -- IT'S NOT NECESSARY TO SHUT DOWN THE CAR.
    To get out of maintainance mode just depress the display button for more than 5 seconds and the regular display will come on and the radio will come back on (if you had it on before going into maintainance mode). Five seconds is kind of a long time so just hold the display button down till the screen changes.
    Maybe this will encourage others to check their voltage.
  16. GranDad
    Australia
    Hi koolingit
    I think you have to look at this from the other way round.
    It’s not that you have to keep the AC or fan off to keep from overcharging the battery it is rather the fact that if you operate the car with light electrical loads for extended periods and you don’t want the electrolyte in your battery to boil the car is smart enough to sense this and bring the charge voltage down to an acceptable float level.
    By applying an electrical load due to the turning on of headlights, AC, fan, defogger etc. you are compensating for the higher (13.8-14.0V) charge, and the battery is happy and wont overcharge while there is a load on it. The Prius is smart enough to sense any change in electrical load and what to do.
    The moderate climate levels here in Australia mean for weeks on end I don’t need air conditioning or fan (I like the window down) or any electrical loads while I drive. If the car did not have this feature my auxiliary battery would be damaged by overcharge.
    Thank you for the tip on how to restore the display it is very useful
    Cheers GranDad.
  17. wildbottom
    wildbottom New Member
    99
    Thanks for the tip! Mine is '05 and on original 12v batt and I always get 14.2V on the Display menu when have it on Ig-Ready. I'm gonna to video the car's Display Menu when I get a chance tomorrow. Let's see if there's any Voltage change like some you guys have seen.
    Curious why you need to buy a new battery since you've a '09. Maybe for the sake of Science.
    Wondering which battery you ordered. I'm going to order mine from Champion ToyotaWorld. It's $115 Shipped.
  18. Patrick Wong
    18,200
    6,501
    I believe that you will find the dealer will not ship the 12V battery (on the basis that it is a hazardous item) despite the fact that you can find it in the parts catalog.
  19. wildbottom
    99
    Well the lowest found is $125 before tax for within 40 miles in NorCal. Thanks.
  20. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    I'm retired and don't drive the car on any regular schedule. When I first got the car in Dec of 08, I didn't know it was a no no to have the radio on while not being in 'ready mode.' The first few months, while I was in the gee wiz phase of ownership, I'd sit in the car for hours going through the manual finding things out (it took me three days to figure out how to remove the cover from the fuse box under the hood.:D) So I was probably in a low state of charge those first few months.
    I've never ran the battery down so low that the car wouldn't boot up but I don't know how close I came before getting the scanguage in May of 09. I guess, by that time, the damage was done.
    I'm not ready to get a new battery yet, but when I do, it will be an Optima.
    I left out the most important part: With my driving habits, this 'feature' doesn't work for me.
