Charging 2007 Prius 12 Volt Battery through the Fusebox Connection?
Discussion in 'Newbie Forum' started by Michael Crestohl, Oct 19, 2022.
  1. Michael Crestohl
    Michael Crestohl Junior Member
    63
    Marblehead Massachusetts
    Further to my previous post is it q good idea to charge the 12 Volt battery through the battery jump connection in the fuse box! If so can I use a regular car charger or should I limit the current used and not rapid charge the battery? Any other tips on charging the 12 battery will be appreciated.
    Thanks once again for the knowledge and wisdom..
    Michael Crestohl, Marblehead Mass.
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    I've often thought about doing that, just to see if there's any differences there compared to connecting my charger to the battery directly, but never get around to it. I can't think of any reason it would be a problem, but maybe my procrastination on trying is based on something? Wonder what others who see this thread will say?
  3. Mendel Leisk
    42,364
    I'm pretty much constantly charging our 3rd gen's 12 volt, from the under-the-hood fuse box, via a wiring harness with plug for my specific charger, tapped onto the 12 volt input to the fuse box, amounts to the same thing. Second gen Owner's Manual recommends a charging limit around 3.0~3.5 amps IIRC? An up-to-date smart charger is your best bet: they go through a charging regimen, then settle down to trickle charging, can be left on indefinitely.
  4. PriusCamper
    13,470
    5,438
    So the only difference is a tiny bit of electrons lost to resistance because the charge has to travel further to get to the battery?
  5. Mendel Leisk
    42,364
    Guess so; they get from the fuse box to battery pretty fast.
    FWIW: Owner's Manuals say to always charge the battery out of the car. Which I don't think I've ever done. I lie: I did once, when I got a replacement battery.
  6. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Why exceed the manufacturer’s charge rate? If you’re pressed for time, remove the battery from the car and charge the living daylights out of it. That way you only destroy the battery, not the vehicle’s internals (worse case scenario). Or keep life simple and charge at a rate recommended by the manufacturer. It’s called the KISS Principle (Keep It Simple Stupid) (no offense intended to most people (just those who abuse their equipment, which I don’t suspect Canadians and the OP are guilty of;). ))
    #6 Doug McC, Oct 19, 2022
  7. PriusCamper
    13,470
    5,438
    I've found that to be the way I do it for a great condition '85 Toyota truck I'm doing work trade to buy. I think it has a voltage leak so I fixed it by having two 12v batteries that I rotate. :)
  8. markismail
    markismail Junior Member
    amesterdam
  9. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    not really the best time of year to be experimenting with much of anything car related in our area.
    If the temps haven't started falling yet further east in your location, it might be surprising when you get in your car next time, if that will be in the next few days.
  10. Isaac Zachary
    Isaac Zachary Senior Member
    2,781
    1,503
    I've charged through the jumper post under the hood. I didn't excede 1.5A. But looking at how thick that wire is it should be able to do a lot more.
    Yes, the longer the wire the more the loss. But that goes for adding any sort of extension cord or similar. I wouldn't worry about a wire that goes from the front of the car to the rear unless we're trying to charge a train.
  11. CR94
    CR94 Senior Member
    2,834
    1,244
    Northwestern S.C.
    That cable resistance is totally insignificant, assuming a reasonable charge current.
    Isaac Zachary likes this.
  12. PriusCamper
    13,470
    5,438
    In most cases that's true... But with a dying 12v battery it becomes way more pronounced of a problem. That's why many on here insist on taking a voltage reading at the jump points rather than directly at the battery...
  13. ChapmanF
    19,042
    That cable to the back of the car is selected and fused for 120 amps.
    At a 4½ amp charge current, any losses there will really be negligible.
    People who are diagnosing a problem with the car may suggest measuring voltage at the jump point, because that way you will catch possible damage or high-resistance connections along that cable, which you would miss by just measuring at the battery. But that's kind of a different situation from just wanting to charge up the battery, when no wiring damage is suspected.
  14. Isaac Zachary
    2,781
    1,503
    Voltage drop is dependant on amperage. No amps, no voltage drop. 120 amps (or there abouts) means a huge voltage drop. The only way around the voltage drop at high amps is to either shorten the wire or make it fatter.
  15. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    I wouldn't quick-charge a battery of that size anyway, just too hard on the little things.
  16. ChapmanF
    19,042
    More specifically, voltage drop (in a simple wire) is proportional to amperage. No amps, no voltage drop, 1 amp, a certain voltage drop, 120 amps, 120 times that much voltage drop.
    Whether the drop at 120 amps is 'huge' or not depends on the choice of wire. If you tried to pass 120 amps over a wire that had been selected to carry 1 amp, you would have a 'huge' voltage drop (and other impressive effects, at that big an overcurrent).
    120 amps over a wire selected and fused for 120 amps will give a voltage drop no higher than the designers expected. And if you're passing 1 amp, or even 4½ amps. over a wire selected for 120 amps, your voltage drop will be tiny.
  17. CR94
    CR94 Senior Member
    2,834
    1,244
    Northwestern S.C.
    No, it doesn't. The problem then is the "dying" battery, not the cable.
