Charging Area wet
Discussion in 'Prime Plug-in Charging' started by yoyoman, Dec 15, 2016.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    5.5 years of plugging in my Prius, through rain & snow. It is clearly no big deal.
    The surrounding enclosure gets wet, but the plug itself is always fine.
  2. Shuping Lan
    Shuping Lan New Member
    Connecticut
    Even if it's ok that the area is wet, it is very annoying. I keep a towel around on raining days. I hope Toyota can implement a design change of the lid and make the lid weather proof when not charging。
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    and while they're at it let's make the WHOLE CAR weatherproof because it can be REALLY ANNOYING with a wet car:whistle:
    Prodigyplace likes this.
  4. priuscatprimeguy
    2,730
    2,640
    Oops! I left my charging door open ALL NIGHT! and there was mildew ALL over the inside to the charging port, where's that weatherproofing towel when you need one?:rolleyes:
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    What's annoying about it? It's DESIGNED to be wet! If it weren't, you'd have to run outside, stop charging, put your charging cord away, and close the lid every time it was raining while you were charging outside!
  6. bps
    bps Active Member
    304
    119
    There’s a very good reason why Toyota designed it the way they did. If the door to the charging plug was waterproof, then moisture would get trapped inside the compartment after charging in the rain (or in humid conditions) and that would be a bad thing. The door is designed to allow air flow to circulate, which allows things to dry.
    Toyota thought this through very carefully. The last thing they would ever want to do is release a plug-in that could not be charged outside. Airflow in that compartment is a good thing.
    blueterp and priuscatprimeguy like this.
  7. CharlesH
    2,798
    1,166
    Roseville, CA
    The J1772 plug and associated electrical protocol was specifically designed to be used when wet. Toyota has a very conservative legal department, and they wouldn't put in a high voltage system unless they felt it was rock solid against liability claims.
  8. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Bisco, Are you still trying to make Trouble ??? Funny.
    I was wondering Again why Toyoto kept the Prime's double-wide charging port in the US, when we don't use the right-side that is used in Europe. How many Primes are sold in the US verses in countries that use the 2-port charging?
    When it's Icey-Snow, the door is hard to close and lock or to pop it open.
  9. bisco
    52,855
    hi ken!
    sales are skyrocketing in japan. we get it to save money. when you add it all up, it makes prime a bargain over the competition.
    how are you liking yours?
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    I thought the right port was for CHAdeMO, which is popular in Japan. Toyota sells a lot of Prius cars in Japan.:)
  11. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    You mean I can drive out of the desert now? :p Thank the heavens! I thought I would have to live in the desert with my new Prime! ;)
