Charging battery with Ebike 48v battery...
Discussion in 'Prius PHEV Plug-In Modifications' started by menardsy, Oct 18, 2013.
  1. menardsy
    menardsy Junior Member
    63
    canada
    I have an idea about making my own PHEV system. I was thinking about using ebike aluminium case battery. Something like 5 48v (Product) in serie which would give arond 250v. Instead of using a enginer converter, I could use a solid state relay to give small burst of current. With an arduino board and an obd reader, I could control when to slow the charge or stop it.
    Anyone has gone in this way?
    Sylvain
  2. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Sylvain,
    Basically this is the PIS system. But of course they have done a lot of programing to optimize it.
    Thanks,
    Dan Lander
    dave77 likes this.
    52,854
    i like it! don't tease us tho, get going and keep us appraised, thanks!(y)
  4. SynEco@eVehicle.co.nz
    139
    How many A/hr in those 48 volt packs ?
    will you charge each pack individually or what your thoughts on that ??
  5. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    The bike packs are usually about 10 amp hours. the state of charge drift systems that just use a big contractor to connect the second pack never seemed to work very well on gen 2. If he is trying on gen 3 it could be even worse.
  6. menardsy
    63
    canada
    The pack are 10ah. The charging would be with the 5 charger coming with each battery. The battery would be disconnected from each others by relays when charging. From the answers I got, the contactor base method does not seem very promising. Perhaps it is simpler to got the engineer / md tech way...
  7. menardsy
    63
    canada
    Ok, I had another idea. Using 4 48v in series lifepo4 battery pack. Use a 5th one. But instead of putting the pack in serie, it would power an ebike brushed controller that can output variable voltage. This controller output would be in serie with the other 48v battery pack, that could allow to control the charging power applied to the HV battery...
  8. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    Not sure if the controller idea will work or not but I can tell you this. You could charge all the bike packs simultaneously without removing the series connections. If the 5 chargers have 3 prongs on the ac cords , break off the third prong. Now you can connect the chargers without removing the series jumpers. I have done this a few times and it has worked fine.
  9. menardsy
    63
    canada
    the problem I can see with the controller is the high frequency that the pwm is generating...
  10. visitor1
    visitor1 Junior Member
    Upstate NY
    I like your novel idea, but wouldn't another problem be the short travel distance this high voltage, 10AH pack would give you before you need to plug the 5 chargers in again?
  11. menardsy
    63
    canada
    Indeed, but I would use a combination of relay to start the parallel charging. The chargers would stay permanently in the car.
  12. hkgngplugin
    hkgngplugin Junior Member
    46
    Hong Kong
    240V, 10AH, that gives you about 2kWH power. but would it be the case that when the voltage of hybrid battery get close to your add on battery, the charging current will get very small or even stopped. For example, if the hybrid battery charged to 230V and your add on battery drained to 235V, there should be almost no net flow of current. In this case you are leaving maybe 1kWH or more cannot use until your hybrid battery (or the whole system including your add on) getting lower voltage.
