Charging cable cannot be unplugged
Discussion in 'Prime Plug-in Charging' started by pearl12970, Dec 13, 2018.
  1. pearl12970
    pearl12970 New Member
    Fremont,CA
    2018 Prius Prime
    I plugged in the charging cable at home to charge my Prius as usual . Had no resistance while plugging it in. When it was fully charged, I tried to remove the cable but it won't budge. I can't seem to unlock the charging cable. It won't let go! Anyone else had this issue? What is the solution?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,870
    New England
    Charging connector locking is working? Did you have your key fob with you?
    HPrimeAdvanced, pearl12970 and bisco like this.
  3. hill
    8,207
    Sometimes, it's just the O-ring inside the receiver that gets rolled over. If that's the case, & you want to reinstall it, put a little bit of silicone lubricant on it then you'll be good to go.
  4. pearl12970
    Fremont,CA
    2018 Prius Prime
    I didn't have the key fob with me! Thank you so much for helping me!!
    bisco and Salamander_King like this.
  5. ashton.agar
    ashton.agar New Member
    New york
    2011 Aqua
    Hi Salamander,
    thanks for your nice clarification. will try as on your instruction at attached picture.
    expect better output on it.
    Salamander_King likes this.
  6. bisco
    49,523
    are you plugging in your 2011 aqua?
  7. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    You can change this function in the cars menu. If set to do nothing when plugged in, you won't need the fob, but this allows someone to unplug or steal your charge cable.
