Charging cable difficult to plug in and unplug
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by DirkW, Dec 13, 2021.
  1. DirkW
    DirkW Junior Member
    Grand Haven, MI
    2018 Prius Prime
    Three Touring
    When I first purchased my 2018 Prius Prime, plugging in and unplugging was easy. Now the plug is hard to plug in and unplug. I have to lean my entire body on the plug to get it to snap in. Anyone have a solution?
  2. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Have you looked for any obstructions on the plug end or the receptacle end?
    Have you looked at the contacts on the electrical connectors for corrosion/oxidation/etc.?
    49,401
    maybe some vasoline?
  4. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    If you have the same problem when using a public charging station, then I would have the dealer inspect the connector on your Prime for damage.
    Similarly, if you do not have the problem when using a public charging station, you should do a careful inspection of the J-1772 connector on your OEM charging cable.
    Be aware that there is a locking mechanism on the Prime which can be set to prohibit the J-1772 connector from being removed from the car. Some of the Primes have a sensor which will not release the connector unless you have your key fob in your pocket. You should not be able to remove a locked connector, even with a lot of force, but you still should check that your Prime is not locking the charging cable and that the locking mechanism is not damaged.
    (Also, I think the suggestion about using Vaseline was meant in jest. Getting grease on the metallic surfaces of the electrical connectors will prevent them from making a secure electrical connection and could result in your being unable to charge your Prime or your having the J-1772 connector overheat.)
