Charging cable error
Discussion in 'Prime Plug-in Charging' started by m8547, Aug 12, 2018.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The other day I got in my car in the morning, and it had a message about some kind of charging problem. It only showed 9.5 miles of range, so it probably charged for about an hour the previous night before stopping. The charging cable had the power light on, and the error light flashing 3 times. Looking that up in the instructions, there is just an unhelpful note to contact Toyota dealer. It says "An electrical leakage is detected and charging is canceled, or there is a malfunction in the charging cable." I doubt the dealer knows anything. The cable works again after unplugging it. I can't think of any way there would be "electrical leakage". It wasn't on a GFCI outlet, but it was in a garage and everything was dry. Has anyone had this problem before?
  2. bwilson4web
    16,552
    I have had a ground fault but it was diagnosed at the power outlet.
    GOOD LUCK!
    52,891
    might have been a one off. i would wait to see if it happens again.
  4. benagi
    benagi Active Member
    525
    280
    Utah
    I had that problem in my garage. Come to find out it was just the wall receptacle. Went to Lowe’s and upgraded it with a more durable one. Problem solved.
  5. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    In this case the brick was hanging from the receptacle, so maybe that was the problem. I've charged from that receptacle before without a problem, though. They really should have put a slightly longer cord on the wall side so it can rest on the ground.
  6. bisco
    52,891
    the o/m instructs you to support the brick weight by hanging it on the wall, taking the stress off of the plug.
