Charging Cable Replacement Parts
Discussion in 'Newbie Forum' started by Gamermama66, May 1, 2015.
  1. Gamermama66
    Gamermama66 Junior Member
    Southern California
    I have a 2012 PiP and the standard 120V charging cable that came with the car has gone bad. Instead of buying a replacement cable assembly from Toyota for $1,200 I would like to replace the defective section of the cable. The defective section is after the inline transformer, near the plug (that goes into the car). I see that for $100 I can buy replacement cable with plug directly from Leviton.
    The help that I need is disassembling the transformer (I don't know the technical term for it) itself. I have opened it and removed screws, but the innards are resisting coming out, and I don't want to force and break anything.
    I would appreciate any help taking this apart so that I can change the bad section out with the new part from Leviton.
    Thank you for any help you can provide!!
    52,863
    welcome! did you check into warranty?
  3. Gamermama66
    Southern California
    Yes - I called Toyota yesterday, gave them the VIN and was told that there was nothing I could do other than going to a dealership and getting a new unit. The picture that I've attached is of the transformer with the cover off - I can't figure out how to disassemble it so I can install the new cable with charging handle.
    Thank you for any help you can provide with this...
