Charging cable stuck in PIP - Any ideas?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Danny, Nov 25, 2015.
  1. mrbigh
    3,686
    699
    Long Island, NY
    Toyota never came up with a fix for this problem; Prius Chat as always been " avant garde" regarding user's complaints and fixes
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    The EVSE for the Prime does not have that orange rubber seal. I guess the engineers convinced the lawyers that removing the seal would not be a lawsuit risk. :rolleyes:
  3. PJN
    PJN New Member
    Rhode Island
    Danny - I have a 2017 prius prime and have same problem. chargepoint and home charger wont click - my port seems plastic not metal in that point - any ideas welcome
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    If it's like the 2012, reach into the connector with a small pick and remove the orange gasket ring. It's not necessary.
  5. steve0826
    steve0826 Junior Member
    30
    Bellevue, WA
    Another victim here. Just got home.
    In my opinion, yank off that metal clip and throw it away. That will save you the trouble of almost having to spend a night in a PIP that won't start, does not give you heat or cold air.
  6. ChapmanF
    19,060
    Anybody tried just plucking out that O ring, rubbing a tiny dab of silicone plumbing grease or silicone brake caliper grease into it, and putting it back?
    Does wonders. I have to do it every few years with the O rings in my air compressor hoses, whenever it's getting hard to put fittings in. A tiny dab does it.
  7. bisco
    52,899
    Maybe, but they eliminated it on newer models, so apparently it’s not necessary
  8. bisco
    52,899
    Can you elaborate? What metal clip?
    Pip will still start, even if you can’t charge it
  9. steve0826
    30
    Bellevue, WA
    Screen Shot 2023-01-19 at 07.43.20.png @bisco
    See picture. When I pull the stuck plug, this metal clip fell out. I had to assume this is the reason why it's stuck. So, throw it away is better.
  10. bisco
    52,899
    thanks, that is interesting. i've never seen that metal clip, or anyone else mention it before.
    it looks like part of those big paperclips for large amounts of paper
  11. steve0826
    30
    Bellevue, WA
    @bisco,
    The paper clip in the picture is to give viewer a reference of the size of the metal clip.
  12. bisco
    52,899
    right, i was talking about the metal clip. looks like the ones that hold large amounts of paper together, but with the metal squeeze prongs missing
