Charging EV portion of the battery going down mountains
Discussion in 'Prime Technical Discussion' started by dalcon95, Feb 17, 2017.
  1. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Let me rephrase my question: how do you insure that you will arrive at the bottom of your final descent with a full battery yet not waste regen potential ?
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I will deplete the battery going up and most likely not fill the full battery potential going down because it wouldn't be a long enough descent to charge going by what others have posted. I just want to obtain all the regenerative electricity I can without loosing it to the ICE braking or friction brakes.
    #1 in Easley,SC
  3. EV-ish
    602
    278
    SW US
    If you went up the hill in EV only, you will regain about half going down.
    But let's say you want to have a full battery at the bottom of the final descent, to use say for city driving. How do you do it ? :)
    dalcon95 likes this.
  4. dalcon95
    512
    653
    I would have to use strictly HV mode see how much electricity would be used in that mode, which it would use some electricity, but don't know how much. I guess by doing that, I give it back descending down.
    #1 in Easley,SC
  5. EV-ish
    602
    278
    SW US
    My solution would be to use our earlier calculation: 1000 ft descent is ~ 6 miles of regen'd range
    Example:
    Say your last descent is 1500 feet, equal to 9 miles of regen
    So start out your trip in EV and switch to HV when 9 miles have been used.
    If the Prime lets you follow kWh consumed you could be even more accurate.
  6. dalcon95
    512
    653
    But wouldn't the car use electricity still in HV mode which would add to the 9 miles?
    #1 in Easley,SC
  7. EV-ish
    602
    278
    SW US
    If my understanding is correct, when you switch to HV mode during driving the car then tries to keep the SoC at the level it is at when the mode change is made. A regular Prius meanders around the 'ideal' battery SOC somewhere in the range of +/- 0.4 kWh so I presume the Prime will let the SoC meander the same, but around the driver designated set point.
  8. dalcon95
    512
    653
    I know on my 2005, the battery would deplete going up a mountain for torque that was needed.
    #1 in Easley,SC
  9. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    In my 2012 Prius Plug-in, you don't need to brake, you can just roll down the hill and the battery will charge. If you apply the brakes, apply them gently, so that you stay in the regen range. So of course it depends on the grade, you can coast or brake lightly as needed. Keep the transmission in Drive mode, definitely not Neutral.
    Using B mode favors engine braking over regeneration. This is bad! I think Toyota only included B mode because cars need to have a "Low" gear mode with automatic transmissions. The Prius will automatically switch to engine braking if the battery is full, so it's not necessary to use B. Ever. If the Prime is different, please correct me, but I doubt it is.
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,033
    Westminster, Colorado
    There are at least two good reasons to use B over riding the brakes.
    1. So someone behind you can tell the difference between simply controlling your speed down the hill and applying the brakes. Riding the brake pedal is unsafe even if you are just regenerating because your brake lights are on the entire time.
    2. So you guarantee you don't accidentally push too hard and slip into friction brake mode.
    Also, the Prime in Ev mode will not use engine braking in B mode unless the battery is full or it needs to control the battery temperature.
    Mark McIntyre likes this.
  11. dalcon95
    512
    653
    So your saying in B mode on the Prime before the battery is full, uses the motor and not the engine to slow down the car. The B mode is supposed to slow the car down.
    #1 in Easley,SC
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Unlike a regular prius, B mode in Plug-in one will actually charge the battery without spinning the ICE. So, less need of using the brake pedal.
    Or B mode and using the brakes as required.
  13. Lee Jay
    5,850
    4,033
    Yes..it regenerates. Unless it can't.
  14. dalcon95
    512
    653
    Does the car need to be in EV mode with the B mode to regenerate the battery full?
    #1 in Easley,SC
  15. Lee Jay
    5,850
    4,033
    Don't know.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    With the PiP - No. I suspect same for the Prime.
  17. Rebound
    3,994
    2,642
    Portland, OR
    Not according to page 246 and 251 of the owner's manual. It says that B Mode will apply engine braking and will reduce fuel efficiency. It is the opposite of what you want to do.
  18. EV-ish
    602
    278
    SW US
    So long as there is room for more regen in the battery I doubt I would ever use B mode.
    Rebound and dalcon95 like this.
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The design philosophy is very simple: if there is a regeneration opportunity, it will be "un-prius" not to capture it.
    Manual may be not detailed enough or a left-over from Prius manual.
    In reality (and I am speaking of the PiP) - when in EV mode and ICE is stationary, B position will increase regeneration (over just let off pedal in D position) and thus 'imitating' engine brake by more aggressive regen.
    See also The one and only Prius Plug-in FAQ! | PriusChat :
    Note that the situation in EV mode is a little different, because the engine is not actually running. In this case, the B gear simply uses regenerative braking more aggressively whenever you let your foot off the gas pedal. So, if you prefer to switch back and forth between gears with your hand, instead of switching between the gas and brake pedals with your foot, you can use the B gear.
  20. dalcon95
    512
    653
    So you need to be in EV mode for aggressive regenerating instead of the engine braking in B mode?
    #1 in Easley,SC
