Charging EV portion of the battery going down mountains
Discussion in 'Prime Technical Discussion' started by dalcon95, Feb 17, 2017.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I am not sure, when driving downhill in HV mode, the ICE is not spinning (up to max. speed allowed) so I believe B position operates the same as in EV mode.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The OM says this about B mode:
    Applying engine braking or strong braking when the
    accelerator pedal has been released on steep downward
    slopes etc.
    I think the "or strong braking" refers to regen. An owner reported that switching in B mode on a slope didn't engage the ICE.
    dalcon95 and giora like this.
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    The FAQ is wrong. B mode engages engine braking, which consumes gasoline instead of regenerating electricity. You're giving the wrong advice. B mode really doesn't ever need to be used, because in D mode, if the battery fills, the car will use engine braking anyway. Whether B is more aggressive or not, I don't know, because I've never filled my Plug-in battery to full by coasting down a mountain. And I don't think there's a mountain big enough to charge a Prime battery, but I haven't tried.
    51,946
    why have b? i thought for the alps?
  5. Lee Jay
    5,850
    4,036
    First of all, using engine braking doesn't use gasoline. The wheels spin the engine.
    Second, a Prime owner said that putting it in B mode didn't rev the ICE.
    Third, I regularly come down a hill big enough to fully change a completely dead Prime battery, at least in theory (it's a decent of almost 6,000 feet).
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I am not giving advices, simply describing my experience with the PiP.
    @Rebound , have you ever tried B position on downhill? or is it just an 'idea fix'?
  7. bisco
    51,946
    i think we need to cite some data or official toyota statements with our opinions.
    dalcon95 likes this.
  8. Rebound
    3,996
    2,644
    Portland, OR
    You mean, like quoting the Owner's Manual?
  9. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    I agree with your message, but I thought B mode constricts airflow to the manifold, thereby increasing the work of ICE rotation. I'm not aware of any active fuel consumption.
  10. Rebound
    3,996
    2,644
    Portland, OR
    I'm done. I cited the page numbers in the owner's manual and no, I'm not going to instrument my car with a scangauge and test it for you.
  11. bisco
    51,946
    the o/m is good, but can often be confusing with the japamerican translations.
  12. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    ■Regenerative braking
    In the following situations, kinetic energy is converted to electric energy and deceleration force can be obtained in conjunction with the recharging of the hybrid battery (traction battery).
    ●The accelerator pedal is released while driving with the shift position in D or B.
    ●The brake pedal is depressed while driving with the shift position in D or B.
    Page 86 of the Prime on-line manual.
    I found similar statement in my (Euro) PiP manual.
    Lee Jay and dalcon95 like this.
  13. bisco
    51,946
    but do we need a distinction of d and b, or are they redundant?
  14. EV-ish
    602
    278
    SW US
    Based on this ?
    A reduction in fuel efficiency from B mode use does not imply gasoline consumption any more than say, a flat tire. I agree with you that both are best avoided.
    #54 EV-ish, Feb 18, 2017
    Rebound likes this.
  15. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I think I will just have to do this situation myself to see what the car does. People have valid points but are contradictory in certain areas. I can believe that a plugin can act differently than a normal Liftback and a can believe that they could act the same. That's what makes it confusing. If I try the scenario, I will listen and feel for the ICE in EV mode and B mode with the battery not full, and HV mode and B mode with the battery not full. I may not do it right away, but when I get a chance. I know how it is in the second generation without a EV mode button. It regenerates in B mode, but uses the engine as a brake.
    #1 in Easley,SC
    jerrymildred and bisco like this.
  16. bisco
    51,946
    we need a scan gauge or such to see engine rpm's and fuel use.
    Rebound and dalcon95 like this.
  17. Rebound
    3,996
    2,644
    Portland, OR
    True, I don't honestly know if the engine vacuum draws in any fuel from the injectors. But either way, you consume more fuel because the engine braking reduces the amount of regenerative braking, so your battery charges less, if at all.
    #57 Rebound, Feb 18, 2017
  18. EV-ish
    602
    278
    SW US
    Yes; I meant that while going down the hill in B mode, I would not expect to see fuel consumption.
  19. EV-ish
    602
    278
    SW US
    This is Graham Davies explaining B mode in a regular Prius.
    Understanding the mechanics aside, it is non-intuitive that an intent to slow the car down on a descent would be accompanied by fuel consumption.
    And even better, the hobbit has his say.
  20. Rebound
    3,996
    2,644
    Portland, OR
    Yes, if no fuel is spritzed into the engine, no fuel is consumed. But if you aren't charging the battery when you could be, fuel consumption increases. IOW, B Mode is not the recommended way to coast downhill and charge up your battery; D Mode is.
    dalcon95 and EV-ish like this.
