Charging EV portion of the battery going down mountains
Discussion in 'Prime Technical Discussion' started by dalcon95, Feb 17, 2017.
  1. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    After reading a page on battery operations for Li-Ion this is correct, NiMH works with more trickle charging where Li-Ion drops off its charge acceptance voltage at various stages during its charge cycle. The charging circuit needs to recognize this cutoffs and properly account for them to protect the overall battery. There is some additional resistance and heat given off as a battery gets closer to full but this is only about 5C delta according to the document I read. And now I have read more about the battery than I want to know, so I am going to go read something useless about politics or something so I can feel dumb again :D.
    dalcon95 likes this.
  2. CharlesH
    2,797
    1,163
    Roseville, CA
    The title of this this thread is a bit misleading. There are not two different physical sections in the traction battery for HV vs EV. It is all one big battery (with lots and lots of cells, organized into modules). The hybrid software manages it in two different ways. When the charge get down to around 20% or so, or you set HV mode, it manages the battery like a standard Prius, in hybrid mode. When the state of charge is higher and you are in EV mode, it manages it as a big traction battery. Separate HV and EV "partitions" are a convenient fiction created by the hybrid software. When we talk about 80% charged, we are talking about the state of charge of the single traction battery. All of the energy going into or out of the battery effects the whole battery.
    Early prototypes of the first generation plug-in DID have real separate HV and EV batteries, but by the time production started, they had changed to the single battery design. Sometimes people come across old documentation referring to the two-battery design, and think that is how it is now.
    #82 CharlesH, Mar 10, 2017
  3. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I understand the traction battery is one whole battery pack and being that I can't re-engineer the software to do it any other way but to use the battery as two partitions as designed, I decided to go the simple minded question using the limitations designed already and not have a long detailed explanation of the "portitions" of the battery. Going by your explanation, you apparently understand the question that was being asked. I wanted to know how the software is engineered to work between HV mode and EV mode in regenerating electricity on the Traction Battery based on going down a mountain with the B drive and whether there is the ability to recapture as much regenerative electricity as possible without loosing it to the frictional brakes or ICE braking. I personally experience the answer myself after getting conflicting answers before actually experiencing it myself. Thank you for the detailed explanation for those who don't have the full understanding of how the traction battery pack is designed hardware and software wise.
    #1 in Easley,SC
    Tideland Prius and CharlesH like this.
  4. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I got 42 miles in EV mode going down a mountain. 1. I did not exceed the speed limit while on EV(65mph). 2. No heat or AC. 3. Saved 4 mi of EV range at the beginning of the trip by switching to HV mode. 4. At the top of the mountain I switched back to EV, with 4 mi of EV range remaining. 5. I used B mode exclusively when going down hill to maintain my speed and recover as much energy as possible. Elevation drop should have been between 3000 and 4000 ft. End of 160 mi trip was 58.9 mpg. Some of the HV was done at 75. YMMV.
  5. Tideland Prius
    16,559
    See the answer immediately below.
    I think with the Prime, previous Prius owners (including PiP) will have to rethink how they use "B" because now it's possible to use it efficiently as long as you're in EV Drive Mode and have sufficient charge such that the engine will not spin.
    He's talking 80% of the usable part.
  6. CharlesH
    2,797
    1,163
    Roseville, CA
    Is it still the case that using B mode while in EV mode is exactly equivalent to lightly pressing the brake pedal? In other words, it just steps up the regeneration over what it is if you just take your foot off the throttle.
  7. dalcon95
    512
    653
    Yes. That is correct.
    #1 in Easley,SC
    CharlesH likes this.
  8. Tideland Prius
    16,559
    ^ what he said. :)
