Charging hybrid battery with RC Charger
Discussion in 'Gen 3 Prius Technical Discussion' started by Hhumber, Feb 11, 2021.
  1. ASRDogman
    ASRDogman Senior Member
    7,665
    3,940
    You may have ruined the MAF and MAP sensors with the brake cleaner.
    There is a cleaner designed just for those two sensors because they are sensitive.
    You could have used alchol on them though. That is what I used because I didn't have the MAP/MAF Cleaner spray.
    But I have it now for the next time. :)
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    o_O
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,064
    1,981
    NJ-USA
    Get a wiring diagram for the engine controls and see what those sensors have in common. IAT is usually part of the MAF, but MAP and TPS1 (or APP1) are separate. They might share a sensor "ground" or signal return circuit back to the computer.
  4. Deener77
    Deener77 Junior Member
    Dublin California
    Tested the sensors they came out fine tested resistance and voltage on MAF was good and back probed and worked fine yet still throwing the codes even after I reset them. Totally confused
  5. Team_Geek
    Team_Geek Member
    62
    32
    MN
    Brake cleaner on a MAF sensor is probably what did it. Both of those airflow sensors are very sensitive to chemicals. Chemical companies sell specific cleaner for these and it behaves very different from brake cleaner / carb cleaner.
    You’re probably going to have to replace them both at this point.
  6. Deener77
    Dublin California
    Thanks they are actually ok there was a short in the wiring also to mention this car has been in 2 accidents but I did find this wiring harness unplugged with no where to go I'm going to post pictures. 3 wires black,red and white 20210506_201000.jpg 20210506_201000.jpg 20210506_200953.jpg
  7. Kermit80526
    Kermit80526 Junior Member
    Where did you get this date code decoder from?
