Charging hybrid battery
Discussion in 'Gen 3 Prius Fuel Economy' started by harryarcos, Oct 3, 2024.
  1. harryarcos
    harryarcos Junior Member
    81
    24
    London
    After nearly 10 years driving the Gen ll Prius, I must say that I am not coping too well having changed it for the Gen III - often press the 'Start' button instead of 'P' Toyota having changed the layout and too many buttons and options!
    Bit disappointed to see the mpg has dropped from my normal 58 - 60 mpg to around 51mpg and wondered if the hybrid battery is charging properly. When braking going downhill, the CHG on the display moves right over to the left, but when just going downhill without braking the CHG barely moves more than a 1/8". Lot of hills where I live. Also, the battery never seems to fully charge, although Dr.Prius indicates it is as good condition and similar to the Gen II.
    Any thoughts would be appreciated.
    52,653
    what year and how many miles?
    the battery sounds fine, but there are a million other things that can cause lower mpg.
    how long have you owned it?
    how many miles have you driven at 60mpg, and how many at 50?
    do you measure mpg when you fill the tank?
    has anything changed in your driving route?
    had any work been done on the car just before the change?
  3. harryarcos
    81
    24
    London
    The post is about changing from a Gen II to Gen III. Only driving it for about a month. The brakes were in very poor condition, as mentioned in one of my posts. The 60 mpg was the Gen II which I had been driving for almost 10 years. Dropped to nearer 55mpg in Winter. The 50 odd mpg is the Gen III. I never fill the tank, so clearly not 100% accurate. Use is similar and the final question is not applicable.
    52,653
    thanks, how many miles?
    'mentioned in one of my posts', if you are posting in more than one thread, you are going to confuse people trying to help you.
  5. harryarcos
    81
    24
    London
    Thanks for your interest. The post was nothing to do with fuel economy and I was just passing on some info. about replacing brake pads. It was also a few weeks back. As for the mileage it is around 63,000.
  6. bisco
    52,653
    got it.
    'any thoughts appreciated' made me think you were looking for help.
    sorry for the 'senior moment', all the best :)
  7. harryarcos
    81
    24
    London
    "Bit disappointed to see the mpg has dropped from my normal 58 - 60 mpg to around 51mpg and wondered if the hybrid battery is charging properly."
    As there are a huge number of posts/people from the US on this site, perhaps I should mention that a gallon in the UK is larger than in the US. I gallon (UK) equals approx. 1.2 gallons (US) so my 51mpg is nearer 42.5mpg(US)
    Bill Norton likes this.
  8. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    If the newer Gen 3 pack is in near same condition as the older Gen 2, what's that sound like to you?
    When batteries get old they behave differently than when they were new, know?
    Besides the possible aging hybrid battery, some Gen 3's have other issues to be aware of. EGR circuit (many threads here on that one ) and depending on how and where the Gen 3 was driven some others to watch out for. Crankcase Oil use, engine misfire, cooling system electric water pump and brake booster / actuator pair.
    There are many threads about them all. That's why it's hard to answer a question about regen and lose of mpg with the observations already shared about your Gen 3. ;)
  9. harryarcos
    81
    24
    London
    Thanks vvillovv - only just seen your post. No EGR on my Prius, oil use ok and no misfire. Fuel use has dropped to around 48mpg (40 US) with the cold weather. Checked for binding brakes straight away, but everything else will have to wait for warmer weather.
  10. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    Your profile indicates Gen2 2004.
    But you are talking about Gen3, which does not have EGR.
    Is this provided by the manufacturer for your model, or is this a successful "appendectomy" done by yourself?
  11. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    All the naysayers are in the hot water now!!!
  12. harryarcos
    81
    24
    London
    If you look at my original post (above) you will see that I have upgraded to the Gen 3. Perhaps I need to change/add to my profile?
  13. bisco
    52,653
    wouldn't hurt. gen 3 over here has an egr
  14. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Yes, you can change the field where the car is listed in your profile.
    You are located in London, Europe.
    The question was that your Gen3 is missing the EGR.
    Was the EGR missing when you bought the car from the dealer or was it removed by someone?
    Is it right-hand drive or left-hand drive?
    What year was it made?
  15. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    The first egr-less turd gen!
  16. harryarcos
    81
    24
    London
    Profile changed. EGR not removed, it was never there to start with. RHD first registered October 2009
  17. bisco
    52,653
    no egr in u/k? interesting. i wish we didn't get one either.
