Charging indicator pipb
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Priusmpg, Sep 28, 2013.
  1. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Hey guys I have pip base and was wondering if there is any system that allowed me to check my car's charge status from my iPhone or even led indicators like the leaf. I think the plugin in advanced has a smartphone app, if I change the my head unit will I get functionality, it just suck having to get in the car just to see the rate/distance/time remaining
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    The Advanced has a built-in cell phone used for the Safety Connect feature (similar to GM's OnStar). This phone is what the Advanced apps use to communicate with the car. The Advanced Apps talk to a server which know how to call the Safety Connect phone. The Base does not have the Safety Connect cell phone, so even with a different head unit, the Advanced apps would not work.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    After you get the feel of charging you will guess really close as to how long it takes to charge x amont of ev miles.
    It takes me from empty to full about 2 1/2 hours to charge. If I am down to about 8.5 miles of ev left and want a full charge it takes about one hour to full charge. This is on 12o volt charge.
    So I think you will get a feel real quick as to how long a charge takes.
  4. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    no one has actually had a indicator installed a indiactor that allows you to see the status from a distance the orange is a bit smal
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    As was previously mentioned- most of us have become pretty good at knowing the recharge state by the amount of time it's plugged in.
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Alright thanks
