Charging issue
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bractar, Apr 2, 2017.
  1. bractar
    bractar Junior Member
    Anaheim, CA
    2014 Prius Plug-in
    Hello,
    I have a 2014 prius plug in. Today, I tried pluging in my charging cable but the orange light on the car was just blinking 10 times and then stopped.
    Can anyone help?
    I posted this video on youtube to show the issue.
    Thank you!
    priuscatprimeguy likes this.
    52,740
    is the timer set?
  3. bractar
    Anaheim, CA
    2014 Prius Plug-in
    no timer, does it look like a timer issue? I'll double check it hasn't been set by mistake.
  4. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I use the timer religiously, unless I forget,but mine doesn't blink like that. With the timer set, when you plugin, the light comes on then shuts off after a few seconds, but no blinking.
    Lithium MPG and priuscatprimeguy like this.
  5. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Isn't there a warning text on the MID?
  6. Pluggo
    608
    534
    Page 101 in the 2012 book: Situation - The charging indicator flashes for 10 seconds. Reason - An error has probably occurred in the charging system. Correction procedure - Turn the "POWER" switch to ON mode and comply with the warning message shown on the multi-information display. (->P. 562) (Gives 9 possible messages)
  7. bractar
    Anaheim, CA
    2014 Prius Plug-in
    thanks Pluggo, I read that too I should have mentionned it earlier. This is a very vague message, and the manual is just asking me to contact a Toyota dealer (see picture)
    I'm using the cable once a day, nothing crazy, it shouldn't break after 3 years. This is the kind of issue that makes me regret getting this car. I know that a replacement cable cost something like a thousand dollars.
  8. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    The cable is covered under the 10 years/150k miles warranty. If it is a cable issue, just take it to a dealer.
    Did you try a different outlet? Have you tried any other EVSE?
    But if you ever need to buy a 2nd 120v EVSE, look for a used Leaf one on eBay, they're about $200-300 last I checked.
    N.J.PRIUS likes this.
  9. bractar
    Anaheim, CA
    2014 Prius Plug-in
  10. bisco
    52,740
    the chargers have gone bad in some 2014's, you can find the threads here. perhaps you should visit the dealer, it should be covered under warranty.
  11. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Pluggo likes this.
  12. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I believe it should be covered under the CA emissions and battery warranty (10/120). But I just read the guide and it doesn't mention anything about the EVSE being covered or not. However, I would think since the mileage and emissions estimates for the PiP are dependent on having a charged battery, it should apply. at least that's how I would approach the discussion with the dealer.
  13. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hello,
    Had this happen at a public charging station. It was the only time I've seen this until now. I would check a different outlet. Possible grounding issue. Just a thought. Good luck and keep us posted.
  14. bractar
    Anaheim, CA
    2014 Prius Plug-in
    I've been using the same outlet for 3 years, but yeah I'll try a different one tonight.
    "the chargers have gone bad in some 2014's, you can find the threads here. perhaps you should visit the dealer, it should be covered under warranty."
    Can you provide the link, I couldn't find the correct thread.
    I made a quick Google search and I haven't found any official "recall"
    Thanks!
  15. bisco
    52,740
    there's no recall. i'll look around and see what i can find.
    edit: search for this title;
    1) 'Plugin Charger issues'. (4 new chargers in this thread)
    2) 'Charging failure' (this member had the light blinking 10 times symptom) turned out to be an ecu.
    #15 bisco, Apr 3, 2017
    Tracksyde likes this.
  16. bractar
    Anaheim, CA
    2014 Prius Plug-in
    I tested the cable on 3 other outlets and I got the same issue. I'll contact the dealer but with a very little hope.
    At the same time, I think this cable would be a great replacement, can you confirm? $300 seems like an acceptable compromise, it would take something like 1 year to amortize from gas savings. (I'd rather buy a new cable on Amazon than ebay)
  17. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    You might want to try someone else's cable or even test it at a public charger before you buy a new one? I think you've ruled out that its an outlet issue. But at this point, it could be the cable/EVSE or the car? Maybe test out another cable at the dealer or try their Level 2 charger if they have one.
    N.J.PRIUS and bisco like this.
  18. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    You need to try using a public charging station. I had a similar situation (I don't remember how many times the light flashed) and tried several charging stations with the same result. Ended up having to replace both the charging ECU and the charger.
    N.J.PRIUS, Tracksyde and bisco like this.
  19. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I may have a used EVSE from a Leaf for $200. if that would interest you.
  20. bractar
    Anaheim, CA
    2014 Prius Plug-in
    I went to the dealership last week, they tested my cable and one of their. They confirmed that the issue came from my cable.
    As expected, the warranty doesn't apply (3 years / 36k miles, I had 38k miles). I asked the price for a new one and the total with taxes was $920. They didn't want to offer any discount or recommend any other cable.
    I called the customer care service, just in case. The lady on the phone tried to find out if another warranty could be applied (hybrid system) but she hasn't found anything.
    So I'll probably have to buy the one from Amazon.
    * Thanks for your offer "PA Prius" but I'm only interested in buying a brand new cable.
    Anyway, Toyota just made a sad and angry customer.
    I'll probably sell this car in the next couple of years and go to a different brand. I can't believe that they don't understand this kind of thing. They could keep customers by being more helpful, customer friendly and honest (selling a $920 cable is absolute rip off).
    N.J.PRIUS, PA Prius and bisco like this.
