Charging keeps blowing circuit breaker
Discussion in 'Prime Plug-in Charging' started by primecandidate, Aug 4, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Owner's manual:
  2. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I have always charged my car via a GFCI breaker and have never had an issue. depending on how things are wired it can be either the car, or something else downstream of the gfci (again, depending on how it's wired) that's causing it to throw...
    or it can simply be a tired gfci
  3. dpframing
    dpframing "Nobody tells me what to do, not even me."
    78
    Chester NY 10918
    2022 Prius Prime
    Same thing happened to me. I replaced my 20 amp GFCI which kept tripping to a 15 amp GFCI yesterday. I believe the Prius uses 16 amp. Solved the problem for now.
  4. Lee Jay
    5,850
    4,036
    It uses 12A on the 120V charger it came with.
    jerrymildred and Salamander_King like this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,598
    2,412
    Left Coast
    Yep, resurrecting an old thread. Car draws 12A @ 110VAC and 16A @ 220VAC
    GFCI plugs do go bad and are engineered to pop open, rather than fuse shut. That would defeat it's intended purpose. The same goes for your panel circuit breakers. When they are going bad they will pop below the rated capacity, again safety is it's intended purpose.
