Charging Light in Charge Port
Discussion in 'Prime Main Forum (2017-2022)' started by EVExtend, Aug 10, 2017.
  1. EVExtend
    EVExtend Junior Member
    2013 Chevy Volt
    Hi all,
    Can someone describe the charging light in the charge port of the Prime? I've searched the owner's manual etc. but can't seem to figure out what the little light in the charge port does when it's charging versus when charging is completed. On, off, blink, color, etc.
    Simple Example (maybe this is even right, haha):
    On = Charging
    Off = Done
    Thanks!
    priuscatprimeguy likes this.
  2. blueterp
    blueterp Junior Member
    30
    23
    Winchester, VA
    That is correct.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    rapidly blinking for a few seconds then off. Low line voltage. (found that out when I tried to charge at Meijer Charge Point station)
    joachimz likes this.
  4. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    Slow blinking, charge later.
  5. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    If you connect the plug with a scheduled 'later' charge set the green light will blink a few times (and you'll hear clicking from the EVSE box, but it goes off after a while). I've never seen any color but green.
  6. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    Mark57, Pdog808 and walterm like this.
