Charging not completed due to charge connector
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pasaman, Feb 5, 2014.
  1. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    It's either or. There's no way to set both.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    You are correct!!
    You can not set both. Other than that, I guess the other guys have suggested about everything else I can think of. I just know I had problems with that am pm thing! Good luck!
  3. CharlesH
    2,797
    1,163
    Roseville, CA
    Right. You can set either a start time OR an end time, not both. All setting an end time does is have it make a (bad) guess about what time it should start in order to be done by the specified time.
  4. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    I set the charger to start at 4am last night and had a full charge at 7am this morning.
    This means it was probably user error. :(
  5. mrbigh
    3,686
    699
    Long Island, NY
    XACTLY....:whistle:
  6. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    By habit I check for the slow flashing green light on the right side of the dash, along with the yellow light in the charging port that comes on for just a few seconds when first plugged in. I haven't experienced the problem others have described with the orange ring, I just push it in firmly until it clicks. My problem is sometimes forgetting to plug it in at all.:whistle:
  7. bisco
    51,950
    i do the same, then go in the house. and five minutes later, i have to go back out and check because i've already forgotten.:rolleyes:
  8. rogerv
    1,639
    317
    Been there, done that. How about driving a couple of blocks and having to go back and see if you closed the garage door? :p
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Same here, exactly! Especially the part of trying to remember! Only some times! :whistle:
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think maybe it has something to do with age! Just maybe. :p At least in my case!!!:whistle:
  11. Pasaman
    289
    115
    Southern California
    I am starting to get some gray hairs :(
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have some brown ones left, but only some. :(
  13. markabele
    5,084
    1,782
    Nebraska
    oh my gosh I do this all the time and I'm only 32!
