Charging nozzle is difficult to connect, disconnect
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Mar 9, 2017.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    Over the past few months, I've noticed the charging nozzle on my 2012 is increasingly hard to connect and disconnect from the car. Any thoughts on why and what a fix may be? I'm in Illinois, so the dealers here are pretty unfamiliar with this car, as it was never sold here.
    49,488
    generally speaking, the problem has been a loose o ring at the bottom of the socket. if that is the case, the solution has been to reach in with needle nose pliers, remove and disgard. it is not needed, and has not come installed on more recent editions.
    mikenancy1 and priuscatprimeguy like this.
  3. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    There is a Toyota tech bulletin on this. You'll probably find that the dealer will do it for free.
    mikenancy1 and bisco like this.
