Charging our cars with 3000W Inverter
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Edsvfr800, Mar 17, 2014.
  1. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    Has anybody charged their car with 12v deep cycle battery using a 3000W (1500 continous) watt inverter. I was thinking about buying a wind generator and using that to charge up a 12 V deep cycle. Or is this too risky for our batteries? My fully charged deep cycle can put out 5 amps for 18 hours or 15 amps for 5 hours.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    It should work ok. I have tested my output from my 120 vac circuit that's connected to the parking lot lights. My Kill-A-Watt meter measures about 12 amps for about 2 hours and 24 minutes then drops to 6 amps for the remaining 10 minutes of charging. My voltage drops to about 109 vac. I have been charging my PIP for two years with no issues.
    PriusGuy32 likes this.
    49,800
    when your battery is putting out 15 amps for 5 hours, what is coming out of the inverter?
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    The inverter controls what current comes out of the battery not the battery, if the battery capacity is 15 amps for 5 hours it should be ok
    SGH-M919 ? 4
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Should be 12 amps if it's hooked up to the Pup
    SGH-M919 ? 4
  6. bisco
    49,800
    what is a pup?
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    d**m autocorrect lol "PIP"
  8. bisco
    49,800
    shows you what i know, i thought you were referring to a hookup point.:p
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I stand corrected, what ever is hooked up to the inverter output (120 vac side) determines how much amperage is drawn from the battery. The inverter can handle up to 3000 watts instantaneously or 1500 watts continuous. Since the charging circuit in the PIP is around 1440 watts it's below 1500 watts.
    Ohm's Law Calculator
    Enter any two known values and press "Calculate" to solve for the others.
    Voltage (E) = Current (I) * Resistance (R)
    Power (watts) = Voltage (E) * Current (I)
    Voltage (E): Volts (V)
    Current (I): amps (A) milliamps (mA)
    Resistance (R): ohms (Ω) kilohms (kΩ) megaohms (mΩ)
    Power (P): Watts (W)
    120 volts, 12 amps =1440 watts
  10. bisco
    49,800
    so that's more than enough to charge the pip battery?
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, 120 volts and 12 amps is worse case scenario, in reality it's a little less
    SGH-M919 ? 4
  12. bisco
    49,800
    that's the same as i'm getting from my wall, so 3 hour charge?
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    For me with .9 EV left it's 2 hours and 34 minutes
    SGH-M919 ? 4
  14. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    No problem with the inverter, but if you want 1440 watts out of it the battery has to put 1440 watts into it. So by Ohm's law, if on the inverter side 1440 watts = 120 volts at 12 amps, then on the battery side 1440 watts = 12 volts at 120 amps.
    In other words, there's a ten to one ratio between the two sides of the inverter when you're calculating the current. If you want 12 amps on the 120 volt side, you have to put in 120 amps on the 12 volt side.
    The OP said the battery will put out 15 amps max continuously, which at 12 volts is only 180 watts. And that's all you can get out of the 120 volt side of the inverter, less the conversion losses.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Oops my bad, you're right
    SGH-M919 ? 4
  16. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I knew that one day all those years of studying EE would pay off! :D
    NR427 likes this.
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    You got me beat, only associate in BMET here
    SGH-M919 ? 4
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Actually Ohm's law is about as far as I go with it these days, having drifted from electronics into systems analysis and programming many years ago. Both fields do need logical thinking, though.
  19. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    So the question becomes: is there enough wind to charge a 2-4 battery bank to run the inverter?
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    if we all "break wind" together:ROFLMAO:
