Charging Prius Prime with Evgo
Discussion in 'Prime Technical Discussion' started by Leonard Enlow, Jun 13, 2019.
  1. Leonard Enlow
    Leonard Enlow New Member
    Corona, California
    2018 Prius Prime
    I have a problem with charging my Prius Prime with Evgo. I have tried two different locations and neither one would charge my Prius. I have set up an account and all that works but it would only charge for a few seconds and shut off. I have my car set up with a charging schedule that I use at home every day. Do I have to shut off the schedule before using a local charger?
    Shaunius likes this.
  2. Tideland Prius
    16,155
    You can do that or select “Charge now” when you turn off the car.
    In the “Exit” or “Summary” screen on the 4.2” MID, use the steering wheel buttons to move left or right to get to the charging schedule screen. Select charge now.
    If you have the 11.6” MFD in the centre of the car, then you can go into the charge schedule before you turn off the car and look for the soft button near the bottom of the page/screen labelled “Charge now”.
  3. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Hey @"Leonard Enlow" welcome!
    In your Entune app under Charge Management you can also click on charge now.
  4. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Yup, if you have a charge schedule setup, you have to select "Charge Now" if you want to charge outside of that schedule. Sometimes when you plug it, it will automatically ask you on the dashboard, otherwise you have to go to the settings.
  5. CharlesH
    2,785
    1,152
    Roseville, CA
    If it is hot out and I want to charge now, I plug it in and press the A/C button on my fob . This turns on the A/C for a little while, but also starts charging. Trouble is, you have to wait about 5 minutes after plugging in for this to work.
