charging procedure for 12 volt battery
Discussion in 'Gen 2 Prius Technical Discussion' started by priusunum, Dec 30, 2006.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    Learned a lot about battery chargers. Thanks.
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(jayman @ Jun 14 2007, 09:24 AM) [snapback]461633[/snapback]</div>
    not only the brake booster pump but one evening as I walked by the wifes Prius I heard the coolant transfer pump cycle and found out that it cycles around 4-5 hours after the last shut down. Wonder what the accumulated current draw is from that over a week?
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Frank Hudon @ Jun 14 2007, 01:29 PM) [snapback]461694[/snapback]</div>
    Hmmm the plot thickens ...
  4. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    I won't change the waterpump unless it had been overheated or have head gasket failure. We can see the rpm and temp sensor using OBD2 device.
    As a maintenance:
    1. clean the intake and EGR valves every 75k miles
    2. change coolant every 5y/50k miles for engine and 7y for inverter
    3. sparkplugs 120k miles
    4. Trans fluid 60k miles
    5. Brake fluid 5-7 year unless moisture is up>2%
    9. pressure wash underbody every spring
    10. oil change 5-7k miles
  5. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    This is not a thing on the Gen 2 as it does not have an EGR system.
    johnHRP and Brian1954 like this.
  6. johnHRP
    646
    189
    KA, DE
    Excel
    ups, wrong tread
