Charging question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Collins, Sep 10, 2013.
  1. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    Do I really have too put the Parking Brake down In order to charge the car .Or is that just toyotas idea for safety.
    All my life i avioed the parking brake as it froze to the brake shoes many years ago during a winter freeze. said to myself No more parking brake
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    No, Safety idea!
    52,755
    good question. i'm gonna go try it without the brake and see what happens.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    I thought He meant the parking (foot brake)! No!?
  5. bisco
    52,755
    it works! i think he meant emergency brake?
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yeah! Thats what I thought!
  7. DLee
    DLee Junior Member
    81
    Yes, it will charge without engaging the parking/emergency brake. The OP does not use the parking/emergency brake because it froze up in winter. But the parking/emergency brake should be used occasionally, or it the mechanism may seize up making the brake useless in an emergency.
    Andyprius1 likes this.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    You realize that without proper supervision the PIP may very well sneak out at night, to coast with other Prii.
  9. Andyprius1
    2,327
    859
    Cool CA
    Like everything " Use it or lose it" Even more interesting if you decide not to use the 12V after car is in ready, just disconnect it, the car will run fine. Think about all the current flow and outrageous electron behavior could be conserved.
  10. patsparks
    10,664
    569
    Adelaide South Australia
    If you are going to rely on the PARKING BRAKE in an emergency you're screwed!! It is pretty useless by design. The rear brakes of any car are only a fraction as powerful as the front brakes and if you can get enough power into the rear brakes to pull you up the wheels will lock and the tyres will skid.
    To the OP, move toward the equator and use the parking brake, there is plenty of room down here.
  11. shiranpuri
    shiranpuri Junior Member
    65
    I'd say it's about time that people start calling it what it is - the parking brake.
  12. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    do people really think the emergency brake and parking brake are different things?
    and to answer the question.. you're fine without it. charges whether it's engaged or not ;)
  13. bisco
    52,755
    that's why i always discharge her before going to bed.:cool:
    Andyprius1 and retired4999 like this.
  14. Bill Collins
    2013 Prius Plug-in
    Ya I meant the Brake that you step on and push down and push again to release. Ya all know the one on the left and against the left side of the car.. Guess it was a dumb question from a new-be as me. In the last few days I found out it not necessary to charging.. Just one of those warnings Toyota has to print
    retired4999 likes this.
  15. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I too remember those old emergency/parking brakes that rarely worked. But they improved a lot in the 1980s - as long as you use them! I bought a new Civic Si in 1986, and when I sold the car about three years ago, the parking brake still worked fine - because I used it all the time. The hand brakes are great for starting off on steep hills, but the foot brake will also keep working if you use it, and it gets serviced every year or three...
  16. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Though you don't need the parking brake for hill starts; just press down hard on the main brake and it holds while you move your foot over to the accelerator. Apologies if that is just standard in automatics; this is the first non-manual ("stick-shift") car I've had. Which reminds me, I must go and drive my wife's car, to remember how to use a clutch...
