Charging Schedule 2026 Prius
Discussion in 'Gen 5 Prime Charging' started by David Lopez, Jan 7, 2026.
  1. David Lopez
    David Lopez New Member
    2026 Prius Plug-in
    Hey, I just purchased a 2026 Prius Plug in, upgraded from a 2021 Prime. Does the new car have a charging setting for when I depart, similar to the 2021?
  2. Eddie F
    Eddie F Junior Member
    27
    Windsor, Canada
    2024 Prius Prime
    SE
    I believe it does. I charge at night when it's cheaper (in Canada).
    You can set up a schedule through the app as well:
  3. jacklee95401
    jacklee95401 New Member
    San Francisco Bay Area
    2026 Prius Plug-in
    XSE
    Yes, it does and it works. Used it a couple of times just to tried it out and now I disable it. Charging stops by itself when it is full so I don't even bother with scheduling.
