Charging ... Tail
Discussion in 'Prime Technical Discussion' started by mr88cet, Oct 9, 2018.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Roger. In this case at least, it’s not likely that it’s due to the AC running, since it was not performing a scheduled charge, and the temperatures were pretty moderate, but I can’t 100% rule that out.
  2. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I've never seen it run the AC on it's own, except for the traction battery cooler which might run at the beginning of the charge cycle. If the battery gets too hot while charging it appears to just lower the charging rate.
    mr88cet likes this.
  3. mr88cet
    2,313
    1,335
    Austin, TX
    Even as warm as it often is here in Austin (TX) I can’t recall it running the traction battery cooler. Perhaps it has and I just didn’t notice.
  4. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    I’ve noticed charge rates fluctuate when the ambient temperature is really high so I don’t think it’s a problem with the charger as much as a problem with the car.
  5. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Here, the temperature has always been within 10 degrees of hot, 80-90, and the problem continues with the particular ChargePoint locations I use. Broadcom site is always excellent.
    AChoiredTaste.com
