Charging the US-spec Prime in Europe?
Discussion in 'Prime Plug-in Charging' started by Chris Grogan, Jan 7, 2017.
  1. Chris Grogan
    Chris Grogan New Member
    Kaiserlautern, germany
    I live on Germany working for the US government and I'm allow to ship US spec cars to Europe. My question is will I be able to charge the car using the European 230 v and 50 hz electricity? I know I'll need a US to Euro plug adapter, but I'm not sure if I'll need more. Thoughts?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Chris Grogan likes this.
  3. Tideland Prius
    16,678
    I've modified your title to be a bit clearer :)
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Pray he does not modify it further.
  5. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    US specs Prime is equipped with J1772 inlet port (IEC type 1 plug). European specs Prime is equipped with IEC type 2 inlet which is physically different.
    The portable EVSE that comes with the US car is no good either as it is for 120V (L1) only.
    What you need is a US specs L2 portable EVSE - this one will work in Europe with an adaptor for the wall socket, just make sure it is rated for at least 15A (I am doing it for over 3 years now with my PiP which has a J1772 inlet).
    Another option is as @JimboPalmer suggested, just make sure it has a J1772 (type 1) plug. The Toyota Europe cord (portable EVSE) for the Prime (called prius PHV in Europe) will have a Type 2 plug while the cord for the PiP (gen 1 prius plug-in) will have a type 1 plug and will fit the US Prime inlet port and will work, however, it will take longer than 2 hours to charge from empty to full as it is rated at 10A while the prime can accept up to ~14A at 230V.
    Another option will be to purchase in Europe a third party portable EVSE, there are several, just make sure it has a J1772 (type 1) connector and it is rated for at least 15A. It will charge from empty to full in about 2 hours.
    #5 giora, Jan 8, 2017
  6. ttait
    ttait Active Member
    273
    163
    Southern California
    Have a look at my post in the charging cable thread. The one I received would work for you just by changing the wall plug to the Euro standard (or make an adapter). It is rated for 50/60 hz, will handle any household voltage, and comes with the proper connector for the prime. And when you connect it to 220 (230) it is a Level 2 charger. And, it was $165 delivered.
  7. WafflesMcDuff
    WafflesMcDuff Junior Member
    Amsterdam, Netherlands
    2020 Prius Prime
