Charging time Doubled!
Discussion in 'Prime Plug-in Charging' started by John11heather, May 2, 2018.
  1. a_gray_prius
    2,927
    783
    IL
    I'm really curious how you can charge your car 10-20min faster than mine. Our L2 EVSE was bought for our Tesla, so it can output 40A at 240V (typically 242V, as displayed on the Model S charge screen) so it's not limited by the input power.
    Can you elaborate on this charge mode? I don't see it anywhere. Now, there is also the question of whether this is a good thing for the longevity of the battery.
  2. John11heather
    John11heather New Member
    Highland ny
    Well, I just did a long trip myself, and the battery indicates 1hr 50 min to full charge.
    From the "charge current" search results I found here, there is no harm to the battery at max charge.
    Control location varies by level variant. Ours is on the steering, right side. Others it's left side of dash, maybe. And I saw the large touchscreen model has the menus on the screen.
    52,854
    different area's have different voltages. also, i wonder if the rest of your house is pulling too many electrons at times, charge time might take longer?
    my big question though, is how it changed from 2h-40m in post #1 to 1h-50m now.
  4. DavidA
    2,349
    1,825
    Chicago western burbs
    Mine takes 1:55 at 240v. In cold weather it might increase to 2:05 for battery heating to happen first. Though, I have unplugged the thing early, at around 1:40 and have seen 100% charge show up on the screen. My guess is that there is some firmware weirdness going on in those last 15 minutes to assure the 100% happens.
  5. a_gray_prius
    2,927
    783
    IL
    When I've unplugged early (and I noticed like 35.5miles indicated, where 36.3 is totally full), I notice that the car kicks into hybrid mode with a mile or so left on battery range when run to 0.
  6. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    Equalizing phase of the cells at the end ?
  7. DavidA
    2,349
    1,825
    Could be. Perhaps mine is just taunting me -- faking like it has stuff to do while I wait an additional 15 to 20 minutes.
    p74atrick likes this.
  8. bwilson4web
    16,535
  9. bisco
    52,854
    it was, but that doesn't explain the L2 charging.
  10. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Are you sure ?
    I also wondered about an inadvertent switch to 8A and from my reading I thought L2 was also Amp throttled. I should just try it out on my car to be sure.
    Andyprius1 and bwilson4web like this.
  11. bisco
    52,854
    absolutely. not!:p and i don't have one to test, thanks for checking it out.
  12. bwilson4web
    16,535
    Confirmed:
    bisco, Oniki and john1701a like this.
  13. bisco
    52,854
    thanks bob, i wonder if that will allow a dryer, air conditioner or other run at the same time.
    can you pot a pic at max amps?
  14. bwilson4web
    16,535
    I would but I'd also have to provide details about the specific wiring at my house. The best we can do is list the power draw and map it into the circuits:
    • 0.96 kW = 8A * 120VAC
    • 1.44 kW = 12A * 120VAC
    • 1.92 kW = 8A * 240VAC
    • 3.84 kW = 16A * 240VAC
    Now the type of outlet helps explain the type of circuit and likely circuit breaker. The circuit breaker protects the wire so it won't let the smoke out: NEMA connector - Wikipedia
    • NEMA 1-15 (obsolete) - ground may be tied to neutral in breaker box, 15A, 12A usable (hair on fire)
    • NEMA 5-15 - has a separate ground pin tied to earth ground 15A, 12A usable
    • NEMA 5-20 - has a horizontal stub on the neutral and can provide 20A, 16A usable
    • NEMA 10-30 (obsolete) - two hot, ground may be tied to neutral in breaker box, 30A, 24A usable
    • NEMA 14-50 - two hot, one neutral, and one safety ground 50A, 40A usable
    john1701a and bisco like this.
  15. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    That’s much more than I wanted to know...........will I be able to find when I need it?
  16. bisco
    52,854
    if you print it out and tape it to your forehead.
    Andyprius1 likes this.
  17. Andyprius1
    2,327
    859
    Cool CA
    People cheat, and read my notes!
    Oniki and bisco like this.
  18. bwilson4web
    16,535
    Are you asking for a sticky quality, "Dummy's Guide to House Wiring and EV Charging"?
  19. Oniki
    Oniki Active Member
    652
    500
    Colorado
    It's going to be a short sticky:
    "YAMV." "Go suss out the circuits to each breaker."
    Huh ??
    "Get Help."
  20. FPN
    FPN New Member
    Chicago
    2018 Prius Prime
    I got the impression from the owner's manual that the maximum charger amperage for the Prime was 16 Amps, and you should not hook them up to a charger that is rated higher.
