charging timer not turns off charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fish lab, Jul 10, 2020.
  1. fish lab
    fish lab Junior Member
    17
    Georgia, Tbilisi
    2013 Prius Plug-in
    hello again, i just notice that my prius is not turning off charging when i set timer to turn off.
    most of i drive using HV mode, so i don't need to charge my car full. i want to charge my car not more than 11-12ml range (about 70-75% not more to save battery) it takes about 40-50 minute using 2 level charger (220V).
    foe example when i set timer to turn on on 10 pm and turn off on 10:50 pm it turns on chargind at 10pm but did not turns off when time becomes 10:50 even on 10:53pm is still charging.
    first i plug charger on car then set timer.
    what is problem? i am doing something wrong?
    52,863
    yes, that is not how the timer was designed.
    you can only use start or stop, not both. using start, it begins charging at the start time, and continues to completion, unless you remove the evse first.
    using end, it calculates the start time based on the existing charge remaing, so the it will finish by the end time.
    there is no way to get an automatic partial charge like tesla and maybe some other vehicles/
    not even the 2020 prime has that capability
    jerrymildred and fish lab like this.
  3. fish lab
    17
    Georgia, Tbilisi
    2013 Prius Plug-in
    thanks for answer. i don't understand why Toyota done that. if they made timer why i can not use as ot should, set startind and ending time both. but anyway that's not bad. i will begin charge and set charging off time and will chage only 40-50 mins.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    I don't understand it either. But Bisco is right. It one or the other. Toyota filled this car with great tech and then crippled it in all sorts of ways.
    By the way, on of my co-workers lived in Georgia for 16 years.
    fish lab likes this.
  5. fish lab
    17
    Georgia, Tbilisi
    2013 Prius Plug-in
    just begin charging and waiting if it will be turned off on set time.
    i like this car and going to upgrade to next Generation plug-in soon.
    Raytheeagle and jerrymildred like this.
  6. bisco
    52,863
    it won't work that way. the only way to get a partial charge is to start it, and then remove the plug before it finishes. it takes some experimentation to figure out when it is the right time to remove the plug, but some have done it successfully.
    no one understands toyotas reasoning, but they don't take questions.
  7. hill
    9,039
    I suppose you could plug the 120v evse into timer disconnect, if that's important to the owner.
  8. fish lab
    17
    Georgia, Tbilisi
    2013 Prius Plug-in
    today just notice strange thing.
    if you set timer to turn off, it will turn off only when ignition is on.
    i begin charging at 13:15 pm and set turn off 13:50. whem i return to car it was 13:58PM and car was charging, when i turn ignition on ( not ready, only push start button without brake pedal) timer worked and car stop charging.
    what a strange times you have Toyota.
  9. jerrymildred
    11,517
    14,170
    Tampa, FL
    You didn't make the timer work. The car has to be OFF to charge.
    I think that if it can't finish charging before the departure time it will try to do the best it can which is keep charging as long as it's plugged in. Departure time isn't a hard time; it's just an approximation temperature can also affect its ability to finish before the set time, so it just wants to get as much energy into the battery for you as it can. I can't find your exact situation in the manual, but it's something like this:
  10. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I don't think you're using the timer as intended. The "Off" timer is to set a time for when you want the car to be fully charged. As you're not giving it enough time for a full charge, it's overshooting the desired time. The onboard timer is not going to do what you want it to do, it's only designed for full charges.
    jerrymildred likes this.
  11. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Echoing what others said, the timer is a simple mechanism, you can set the time to start or the time to finish, it has no ability for a partial charge, unless you want to take the external step of using a mechanical timer at the wall, but that has no guarantee of charge level.
    Personally, I think the OP is stressing too much about battery preservation. Toyota has been making hybrid tech for >20 years and they do a good job with battery health management. Just charge it up and drive it. Look at this way: if you end up losing 3-5% more capacity over a few years relating to charging it frequently, the real world impact is slightly less range on EV (such as maybe 1-2 miles/KM), which would be powered by gas instead, which will literally be a difference of pennies. Not worth stressing over... :)
    The same reason I say it is insanity to consider replacing a hybrid battery due to reduce capacity, unless of course it is an outright failure, since In doing so would only save pennies on the dollar, you will never make the (multiple thousands of $$) money back ahead of just using slightly more gas... :whistle:
  12. bisco
    52,863
    o/p is a funny guy :cool:
