Charging timer nuisance
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Montaraman, Jun 10, 2012.
  1. Montaraman
    Montaraman New Member
    This may be a dumb question, but why wasn't the charging system designed so that you could just plug it in and not worry about overcharging, which the manual says will shorten battery life? I can see the advantage of the timer if your electricity rate is lower at night, or something like that, but otherwise it is a nuisance to get out of the car, plug in the charging cable, then get back into the car to set the timer.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    First, the car won't overcharge of you leave it plugged in all night.
    Second, on a Basic PiP, once you've set the timer, you just power off the car, press and hold the timer button until the charge timer icon illuminates, and that's all. Plug in the charger and the car will charge as programmed.
  3. stacey
    stacey ☆☆☆☆☆
    115
    23
    Lancaster, PA
    I just shut the car off, press the timer button and double-check it's the one I want, then lock up and plug in the car. In my experience it's not necessary to hold the timer button unless you wish to change the time or switch between the start and end times. I always use the timer to end at 0700 and if I need to charge at any other time during the day, I don't bother with the timer and let it start charging immediately. That's not very often though.
  4. Sandiegomom
    Sandiegomom New Member
    109
    28
    San Diego
    You don't even have to wait till you turn the car off to set the timer. I hit the button (not hold, jut a quick press) while I am driving home from work, whenever I think of it. Works great.
    radiocycle likes this.
  5. yukit
    yukit Junior Member
    38
    SF Bay Area, CA
    I charge my car at home & work, so I have to cycle my "finish time" between 7am & 6pm each time I charge.
    Maybe there is a shortcut to remember multiple presets, but I have not figured it out.
  6. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Can you set one to be a start time 3 hours before you need it to complete and then toggle between the two? Or does it only allow one time stored?
  7. CharlesH
    2,797
    1,165
    Roseville, CA
    You can store one start time and one end time and toggle between the two. If you just tap the timer button to set it, it will be whatever the last one was.
    yukit likes this.
  8. blmoore
    blmoore Threadfinder
    31
    Pennsylvania
    You don't have to set the timer - if you don't, it will just start charging once you plug it in. It won't overcharge, but the downside to not using the timer is that if it charges and you aren't driving until hours later, you won't begin with full battery capacity. The ideal is to set it to be fully charged right when you're heading out. I too wish there were more than one start and one end preset, tho.
  9. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    It's not a nuisance, it's just an added feature.
    Why do people have to misconstrue facts and overcomplicate things?
    The Plug in Prius cannot, and will not, be overcharged when plugged in.
    There is no need to get hung up about charge delay.....
    The primary purpose of the charge timer is to delay an overnight charge to take advange of more economical/ecological charge rates. If that works for you, take advantage of it.
    It's not a bad idea to delay a charge if you know the car won't be driven for MANY hours, like maybe while at work all day, or sitting in the garage overnight. But even that is no big deal.
    LiPo batteries should not be left fully charged, and unused for LONG perionds of time, because they can develop a decrease in capacity. We are talking days and weeks of idle use, fully charged.
    If already set, the charge timer button can be activated by a simple push of the button, any time prior to plugging the car. No need to go in and out of the car. The little green timer icon tells you it's set.
    It's like saying a sunroof is a nuisance because you have to open it to enjoy it, but then you have to close it in case it rains. What a royal pain.
    denovo and radiocycle like this.
  10. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Thanks for setting the record straight 9G-man! It's really a well designed system and very simple to use.
    radio
  11. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Last night was the first time I actually used the timer, I normally just plug it in and let it fill for when I need it.
    So I would normally leave for work and the range would say 10.6 or so miles.
    Used the timer to finish my charge at 6am. I left for work at 7:15 and it showed 11.8 mile range. Thats really the highest estimated range I have seen.
    I will play with it tonight and set the timer to finish at 7:15 am and see if my range is higher.
  12. tarantoga
    tarantoga Junior Member
    52
    Alameda, CA
    I also see about 11.8 or 10.6, but it depends on whether I have the AC on or not.
    Switching AC off immediately extends the displayed EV range from ~10.6 to ~11.8.
  13. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Interesting, I never use the AC in the morning. I don't see any difference with the AC or off, it doesn't adjust my EV range I see on the dash.
  14. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    AC off in this case means the whole climate control system is off. Even if you have AC off, but the fan on, it'll display the lower EV range.
  15. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I press the off button for the Climate unit, I see it still shows the airflow as bringing in fresh air and the outside temp, but nothing else.
  16. devprius
    devprius /dev/geek
    979
    291
    I typically charge at home at 1am, which means it's finished at 4am. I don't get into the car until 9am or so. So it's had 5 hours to sit. SoC reads out at the max of 85% and I have 10.3 miles of EV range (AC is on). I also charge at work. It usually has just finished when I get into the car. SoC again reads out at 85% and 10.3 miles of EV range. Letting it sit for 30 minutes or 5 hours while fully charged & plugged in has had no effect on range or capacity.
    I've said this before, and I'll say it again, but I have a really hard time believing that Toyota's engineers would design a battery system that is so sensitive that leaving it fully charged for a few hours before you use it would degrade the battery and reduce capacity. Those warnings in the manual refer to leaving the car fully charged and unplugged for weeks or months. If it's plugged in while sitting for days or weeks, I'm pretty sure that the system will monitor the battery and give it a boost every so often.
  17. devprius
    devprius /dev/geek
    979
    291
    Then the system is fully off. If I have the climate system on, I get an EV range of 11.4 miles. With it on, it drops to 10.6 miles.
  18. Montaraman
    Thanks for the clarification. I wish Toyota would hire some decent tech writers for their manual. I find it more difficult to understand than it should be.
  19. CharlesH
    2,797
    1,165
    Roseville, CA
    I'm sure they did. It's not their problem if you can't read perfectly clear Japanese. :):)
  20. yukit
    yukit Junior Member
    38
    SF Bay Area, CA
    Good suggestion. works for me.
    Thanks,
