Charging timer; use or not?
Discussion in 'Prime Plug-in Charging' started by MikeDee, Jan 17, 2017.
  1. ruby
    ruby Member
    130
    78
    So far I've used both 'charge now' and timer. Both have worked fine. The timer has finished an hour or two before the finish time I requested, according to the emails I get from Entune.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I'm reasonably sure it cools the cabin and draws cabin air to cool the battery.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Can you explain what do you mean by active?
    Prime and PiP have forced circulating air cooling, not natural circulated - for me this is active.
  4. Lee Jay
    5,850
    4,036
    It's the difference between active air cooling and active water cooling.
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Correct terminology.
    #25 giora, Jan 17, 2017
  6. Trollbait
    12,832
    dammit, the web ate my post.
    Yeah, I dropped the liquid there. Liquid is better for in terms of maintaining battery life, and reducing winter loses.
    The extra cost and weight, mean active air is fine for a PHEV with a smaller battery. There is still the ICE in the event excess heat or cold effect EV operation.
  7. Tim R
    Tim R Member
    St. Louis, MO
    Winter here, so time of day didn't seem a concern for heat, but now I know why this is helpful. I had mine set on, but then twice I forgot when I plugged in day-time that I had it set for ready at 7:00 AM. Turned it off now.
  8. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    For whatever it's worth, I'm not optimistic about the P.Prime's air-cooling idea. Sounds like a repeat of the Leaf, which started it with air cooling (some claimed "no cooling"), got hit with a class-action suit, and switched over to liquid cooling.
