Charging while driving with gas engine
Discussion in 'Prime Plug-in Charging' started by Colorado_Hiker, Aug 3, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Sounds like your getting dragged into the 21st century:p.
    Technology is grand(y).
    52,773
    kicking and screaming.:eek: funny thing, my older brother (68) is way ahead of the curve. always was a gadget guy, latest and greatest, and has stood in many i phone lines.
    Raytheeagle likes this.
  3. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I was just as bad:cool:.
    Didn’t get an iPhone until 2 father’s days ago. Before then I had a flip phone for 11 years:eek:.
    Now it’s all good(y).
  4. ct89
    ct89 Active Member
    323
    266
    New England
    So if I work through the math...
    You used 35/39.4=0.888gal instead of 35/60=0.583gal or an extra .305gal to charge to 80%
    At $3.00/gal, that's ~$0.92 for your 23 miles or about 4 cents/mile.
    HV mode was costing you $3.00/60mpg = 5 cents/mile
    EV mode would cost 4 cents/mile if you paid around 20 cents/KWh
    The interesting part thing here is if you would have then switched from charge model to EV mode until your battery drained, you would have in theory gone 58 miles (35+23) on the same 0.888 gal of gas which works out to 65mpg...
    Do we really expect charge mode + ev mode for a long highway drive to exceed HV mode over the same distance?
    OR, is the 65mpg vs. 60mpg just rounding errors and it's about the same (my expectation).
  5. bisco
    52,773
    i think we expect charge mode + ev mode to be less efficient than hv mode, due to conversion losses.
    as far as cost goes, that all depends on what each user pays for gas. electric cost doesn't matter since ev comes from gas in this equation.
