Chassis Stiffening Plate
Discussion in 'Newbie Forum' started by timkf1, Apr 6, 2010.
  1. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    You'll just have to use the good old scientific method of trying it to see what happens. If a theory disagrees with experiment, it's wrong. :)
    It should also be mentioned that tires make a huge difference to handling. The stock 185s are too skinny and too biased towards mileage.
  2. timkf1
    timkf1 New Member
    Cincinnati
    I understand the concept, I just question how well it works. Look up structural racking. you would have to move the bolts closer to the outer corners (based strictly on "scientific theory") in order for this product to work more efficiently than the factory brace regardless of material, but especially considering steel is stronger than aluminum even though it is a thicker bulkier piece of aluminum...You would need to minimize the forward and rearward movement of either side of the vehicle (moving in opposite directions) to minimize the vehicles efffective swaying unless they are saying that the factory piece doesnt work in one of these applications.....I'm just saying....
  3. timkf1
    timkf1 New Member
    Cincinnati
    I will totally replace my shitty Integrity's, but I purchased used, and I'm not replacing them until they are worn out. I'm considering upgrading the wheels and tires with some Scion Tc wheels considering I work at a Toyota dealer, but you're right. Totally worth mentioning.
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Timkf1,
    Brian of BT Tech (RIP) got the idea for the Prius brace because some Corvettes (also with large rear hatches) had a similar problem. And he sold many braces for the Corvettes, long before the Prius. He worked at a Corvette speed shop, besides the Telescope shop, where he designed stiff plates for Telescope mounts too.
    As you may have read I am convinced the plate is well worthwhile.
    The problem with "scientific theory" is that it rarely is considered to the 2nd, 3rd and 4th order complications of a modern engineering problem by people other than the specialist engineers that have trained themselves up for decades (before a car company will trust them to do a car chasis design). To truely understand the flex in a 2nd generation Prius is going to require that specilist engineer background expensive modelling system or mechanical test rack, or both. Getting to the root of the Prius chasis flex is just so uncertain short of that half a million dollar investement.
    Or we can just pay the $160 for the BT Tech plate, and give it a try.
    Now, if your alignment is flakey, you may not have much improvement. That is the first thing.
    The main thing the plate does, is reduce the oscillatory period of the rear of the Prius to something that allows the driver to more accurately control the car. If your used to driving a vehicle with a 1 to 2 second rear end shimmy, well, your probably not going to appreciate the BT Tech plate. But, if you do not want to wait a second for your control inputs to have an effect, well, the BT Tech plate is for you.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Correct. The brace would be completely useless if the factory piece worked as well as the brace. I think we can agree on that. :rolleyes:
    The factory piece does what the factory was trying to fix, the center tunnel cannot flex outward, under tension. The brace adds the ability to not flex the center tunnel inward, under compression.
    The question you need to ask, is 'Do I care if the central tunnel flexes inward, under compression?' This is not a question we can answer for you.
  6. timkf1
    timkf1 New Member
    Cincinnati
    I REALLY appreciate you guys providing me with some first hand knowledge. I think I'm convinced. Do you think the "el-cheap-o" version for $59.00 is as good (other than quality) as the BT-tech? or should I just spend the $$$ on the BT tech brace and move on?
    OR, is there a better bang for the buck? I'm probably gonna try to find a used one considering there's really no "wear factor"...
  7. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I have the cheapo ebay plate, it works fine. The real BT plate has hollows between ribs, so may be lighter. (They can't be for cooling)
    http://www.gurexdepot.com/image/priusplate/Plate06.jpg
    http://www.evnut.com/images/prius/stiffening_plate/stiffening_plate05.jpg
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
    If its just a placebo, then the $59 one is probably just fine. :madgrin:
    [ducks and runs for cover]
  9. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    It's good to consider the options. Tom's also makes chassis parts for the Prius, including a rear brace. It's quite a bit more expensive, especially since it involves rerouting the exhaust. But it works much better - I've heard it described as 'the BT brace on steroids' (I think that was Presto) So, it all depends on how many bucks you have and how much bang you want. :)
  10. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    On paper and in pics, the $59 G7 plate appears to be substantially the same as the $165 BT Tech plate -- 6061-T6 aluminum, black anodized finish, stainless steel bolts.
    I have the BT Tech plate, am happy with it, and was glad to support Brian in his efforts to improve the Prius.
    But with the onset of the Great Recession, in all honestly, if I were to buy a stiffening plate today, I'd try the $59 G7 plate. I just wouldn't be able to ignore the $106 savings for what appears to be substantially the same product.
