Cheap front spoiler
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PA Prius, Oct 3, 2017.
  1. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
  2. SlidingBike
    SlidingBike Active Member
    171
    112
    Fremont, CA
    Same here. My vehicle front Valance protector was severely ruptured by the previous owner(may be their parking stopper bump is bit high). I am thinking of replacing it. Not sure how much does it cost to fix it (labor cost)?
    Raytheeagle likes this.
  3. SlidingBike
    171
    112
    Fremont, CA
    when I quickly googled, found bit cheaper options. :
    #3 SlidingBike, Oct 3, 2017
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    The part seems cheap enough and if you're willing to help, we can sort it out at the next Bay Area meet up ;).
    One option with very cheap labor (y).
    SFO likes this.
  5. SlidingBike
    171
    112
    Fremont, CA
    I am in. When and where is the next BA meetup?
    SFO and Raytheeagle like this.
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    November 11th. Location TBD:whistle:.
    Looking for available options(y).
    SFO likes this.
  7. SlidingBike
    171
    112
    Fremont, CA
  8. SlidingBike
    171
    112
    Fremont, CA
    why I cant insert URLs in my post? they are disappearing..
  9. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Might be time to sweeten the pot for potential available options ;)
    Guessing I could try a little bribery and see it that finds available space between now and the 11th :whistle:
    Do you think someone would play host for a jug of Synth and or a few packages of the best (slightly spicy) sausages I've eaten this year? (yes, I'm hording sausages now :sneaky: )
    On second thought, could just keep the sausages and offer up two (2) jugs of Synth instead :p
    Raytheeagle and ckam1989 like this.
  10. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    I don't mind hosting, it just maybe far for our South Bay travelers ;).
    If a midrange geographical option wouldn't mind hosting, I bet we get a great turn out (y).
    SFO likes this.
  11. SlidingBike
    171
    112
    Fremont, CA
    I find one option as Fremont Elizabeth park(lot of space, open for public), even we can have some food and drinks arranged there.
    Alternatively is there any such option in or around Pleasanton Or Palo Alto area(to make it reachable for other far east folks as well)
  12. Mendel Leisk
    38,669
    You can take that front piece off without even raising the car. I'm not sure if a 2012 PIP would be identical, but ours was moderately chewed up from concrete wheel stops; I just removed it and repaired, mostly from the backside, using some fiberglass mesh and two-part epoxy.
    It's a poor design, btw: it's a low/fragile piece, that slides up and over concrete wheel stops relatively easily, then catches royally, as you back off.
    PA Prius likes this.
