Cheap Steering Wheel on Prime Advance?
Discussion in 'Prime Main Forum (2017-2022)' started by jrodz09, Dec 6, 2018.
  1. jrodz09
    jrodz09 Junior Member
    42
    22
    Visalia
    Hello everyone!
    Has anyone else been having this same issue with the heated steering wheel? First time I have had a car do this to me. Starting to look pretty ugly.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
    An unintended consequence of a heated steering wheel apparently that heat destroys the "pleather" that Toyota uses called Softex..
  3. Diemaster
    Diemaster Active Member
    298
    263
    so. cal
    then shouldn't the (non-moonstone) heated seats show the same marks?
  4. Georgina Rudkus
    3,559
    2,599
    Taylors, SC
    The seat heaters apparently spread the heat over a larger surface area than on the steering wheel. Engineers call it the principle of unintended consequences. Vinyl's start to soften at about 180 degrees Fahrenheit and droop at about 300.
    Natural materials like leather are a lot more heat resistant up to 400 and slightly beyond.
    #4 Georgina Rudkus, Dec 6, 2018
  5. jrodz09
    42
    22
    Visalia
    That sad part too is that there no heat up in that 12 o’clock position. :/
  6. Concerning the wrinkle...
    No...?
    jrodz09 likes this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Is this the same issue I have been seeing on PC on peeling steering wheels? Are they specific to "heated" steering wheels? Mine does not have heated steering wheel and peeling... at least NOT YET.
  8. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Could that be related to Sun UV damage?
  9. Mendel Leisk
    42,259
    I like that.
    Georgina Rudkus likes this.
  10. upnorth
    upnorth Member
    NW Wisconsin
    At 20,000 miles and about 1 1/4 northern Wi winters I do not see any damage of this kind on my steering wheel. I use the heated steering wheel a lot, every day this time of year probably through most of March. Thanks for pointing it out, will keep an eye on it.
  11. jrodz09
    42
    22
    Visalia
    I do have almost 60k miles, but I have owned around 10 cars and a couple with more miles than that and never had this degraded steering wheel issue. Do not know if it’s only affecting the heated steering wheels, but that’s what I am working with.
  12. padroo
    padroo Senior Member
    2,763
    2,253
    I wonder if there is some kind of solvent or even hand cream involved?
  13. Mendel Leisk
    42,259
    There's been at least one other thread on this, and the common denominator was 4th Gen with artificial leather, not necessarily heated.
    jrodz09 likes this.
