  1. SalixIncendium
    SalixIncendium Tree Hugging Environmentalist Wacko
    155
    68
    Dayton, OH
    Any thoughts on why I would be getting a "check antenna" message on my audio display when listening to satellite radio? It's not persistent, but I do notice it on occasion when glancing down at the display.
    There does not appear to be any reception issues.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Have you paid attention to your environment when you get those messages.
    With my Portable Garmin GPS, which also uses satellites, if I drive through a forest or area with a lot of cover, the device will lose communication with the satellites. It will then sometimes annoyingly start giving me repeated warning messages, or directions until I'm in the clear and it reestablishes communication.
    I would be curious if there is any connection to the happening and the environment you happen to be driving through.
  3. SalixIncendium
    155
    68
    Dayton, OH
    If memory serves, it's been overcast when it happens, but I don't recall seeing the message prior to this past Wednesday.
  4. SalixIncendium
    155
    68
    Dayton, OH
    Also, I was in a open area so there was nothing physical (trees, buildings) interfering with the signal.
  5. The Electric Me
    9,083
    5,798
    Hmm....
    Maybe you need to check your antennae?
    I don't have satellite radio so at this point I have to give up. I can't really tell you whether that is normal operation or not.
  6. SalixIncendium
    155
    68
    Dayton, OH
    I did a cursory check of the roof antenna to ensure that it's on and tight, but given that it's still under warranty, I'll likely defer to the Toyota service department. Thanks for the response.
