Check cruise control system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fadi75, Sep 15, 2018.
  1. Fadi75
    Fadi75 New Member
    Jordan
    I have a 2010 package 5 prius.
    And when i press on the cruise-control button, a Message appears staying check cruise control system, and when i press the LKA button, a check LKA system Message, most of the time this Message appears when i press one of these button.
    But sometimes the LKA and cruise control systems work just for a few seconds and then the Message appears and they stop working
    Ps. Both the systems worked fine a while ago.
    Please help and Thanks
    52,404
    welcome!
    sounds like a loose wire. maybe a bad spiral cable from the steering wheel to the systems.
    you really need tech stream for a proper diagnosis though.
  3. enginestar
    enginestar New Member
    Redmond, Washington
  4. enginestar
    Redmond, Washington
    Hi! Any updates after you experienced that problem?
    I have my 2010 package 5 with the same issue
    And it really works most of the time but this exact same message shows and won't go until I turn off the cruise control
  5. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    I have a 2010 package 5. I had the same message along with "Check PCS" Amber ABS light, Red Brake light and the Master Caution. For me, it was a left rear ABS wheel speed sensor.
    Raytheeagle likes this.
