Check Engine Comes on -- Camry
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Feb 27, 2018.
  1. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    As long as the CEL is still intermittent, the problem isn't hardcore yet. Its only when it gets to a certain out of spec, that it develops into hardcore, where the light stays on. At that point, the fault registers by the computer needs to be fixed before the light goes away.
  2. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,155
    1,775
    Mars Hotel
    So, once again. It only does it when the car is cold. If the engine is warm and I make the stop, no issue.
    It did it yesterday morning. The light was out by this morning.
    Don't imagine the injectors need cleaning. The car only gets Chevron with Techron gasoline, because any other gas (well, almost any other gas) causes the Check Engine Light to come on with an O2 sensor code.
    Which, also disappears in about a day or so. Funny, I can buy non-ethanol fuel from any source and dump it in the Camry and no engine light. But, if I buy Shell, Texaco, etal, the light will illuminate.
    kris
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Can you just get a scantool to scan for codes, instead of giving us what happened blablabla? That saves time and all that!
    Have a simple scantool handy, and scan it. Post codes here. That's all and simple.
  4. bwilson4web
    16,210
    See if the exhaust pipe has a wet layer of oil and carbon. That will kill the catalytic converter and O{2} sensors. Get a cylinder pressure test gauge and then:
    1. Pull the plugs and inspect for evidence of oil burning.
    2. Do the cylinder test that checks for oil ring leak.
    Replacing the O{2} sensors and catalytic converter without fixing the root cause, oil leaking around the worn piston rings is like bailing the boat while ignoring the leak:
    Wet Compression Test Results Explained
    #24 bwilson4web, Mar 8, 2018
    RCO and Trollbait like this.
  5. Trollbait
    12,534
    These are likely the same issue.
    She has one in the form of Toyota software on a laptop, but the program is in demo mode and only has so many uses before lock out. I recommend checking if local auto stores pulls codes for free.
    Cousin has an older Camry with over 200k that requires oil added every 6 to 8 weeks, and it is getting the CEL on at times.
    RCO likes this.
  6. cyberpriusII
    1,155
    1,775
    Mars Hotel
    Funny thing about this Camry. We got it brand-new. Had to wait a bit for it because we wanted a Japan-built car and we also wanted a manual transmission-- even back in 2003, they were not exactly rushing standard transmission out to America. Dealer wasn't cooperative until they found out that was the ONLY acceptable deal. And, we did get a very decent deal.
    But, the Check Engine light came on upon a week or so after buying when we filled it with some gasoline or other. The dealership said O2 sensor and of course it was replaced under warranty.
    Normally, we only buy Chevron because it is the only local station, but a month or two down the road (car was only a few months old), CEL again. Again, another O2 sensor under warranty. Fast Forward, rinse repeat, but this time they decided that while the code was O2, the real problem was the very pricey vehicle computer, which they then replace under warranty.
    By this time we had sort of connected the light coming on with us buying gasoline at a station other than Chevron, but Toyota dismissed the idea.
    And, again, after a month or three, we bought Texaco and CEL comes on. This time, I asked the independent mechanic who usually works on our cars what he thought. He is older and has been around forever and does not RELY on the computer's diagnosis to the excusion of his experience, although he does not dismiss the technological aid.
    Anyway, I forget his answer but it was something about the gasoline formulation and that problems could be resolved with a simple adjustment of something, which he would be happy to do for nothing, but he also said it was not an issue that really needed to be addressed and don't worry about.
    Never had any driveability issues, never any MPG drop, etc. in 15 years, so we took his advice and pretty much only fill up at Chevron, although Kroeger gasoline in a nearby large city seems O.K. too. And, as I said, we ocassionally fill with non-ethanol when buying gas for the chainsaws and the non-ethanol is not only accepted without complaint, but it seems to give the car a bit more power on hills (may be our imagination).
    RCO likes this.
  7. Trollbait
    12,534
    My thinking with the CEL due to gas brand could be expanding its triggers as the car ages.
    I think trying to get a code now is better than waiting. Probably nothing, but it could be an early warning to something major.
    Know anybody with a Scangauge or similar? Not only can they pull codes, but they can tell you operating parameters beyond what the dash tells you. They tell you if the car is running in closed or open loop, which relates to the oxygen sensor.
    RCO likes this.
