Check engine just lit-up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kensiko, Mar 28, 2015.
  1. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Before plugging it
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  3. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Thanks. Will this works ? ELM327 Super OBD II Bluetooth Auto Car Scanner for Android Torque elm327 OBD2
    52,803
    12.6 is low for a new battery before it is installed. you should smart charge it to 13 volts.
  5. cyclopathic
    3,292
    547
    2014 Prius c
    Most likely it will (if you find reviews, you'd know better). What I found biggest issue isn't if it works, it is how many tries it'll take to link it. For $4.4 you have not much to loose. BTW battery voltage is available on OBDII you can plot it w/o getting your hands dirty
    UPDATE: found this discussion online
    FORScan forum • View topic - Attention, cheat: ELM327 v2.1
    Looks like there are some issues with v2.1.
    I have v1.5 (bigger one) and it works OK except it is a b!tch to link up sometime
    #25 cyclopathic, Apr 9, 2015
  6. Mendel Leisk
    42,293
    You'll probably be fine, but it's probably a good idea to hook a new battery up to an appropriate smart charger, let it run 'till it's happy with it. Nothing stopping you from doing a charging session post-install, wouldn't hurt. You want a smart charger in the 3~4 amp range.
  7. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    I have one. Will do on the first occasion.
  8. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Issue came back after 1 or 2 months.
    I rarely use the car since I have a Leaf. It is in fact for sale as owning 2 cars doesn't make much sense since I work from home.
    So I called Toyota, we're talking about 500 CAD$. Their mechanics suspect a faulty oxygen sensor. I looked for replacing it myself with my father. He just took the car yesterday and removed the sensor at the manifold. He measured the resistance and it is about 14 ohms where it should be 1.8 to 3.4 ohms. Great !
    So I shopped for a new sensor and discovered that there are 2 sensors, one upstream the catalytic converter and the other, downstream. Am I right to replace the one upstream ?
  9. cyclopathic
    3,292
    547
    2014 Prius c
    what was the error code again?
  10. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
  11. cyclopathic
    3,292
    547
    2014 Prius c
    P2a00 Toyota A/F Sensor Circuit Slow Response Bank 1 Sensor 1 OBDII Engine Light Trouble Code | Engine-Codes.com
    Check that battery has a good ground contact, no terminal corrosion and it is charged. This may be causing problem too.
    But this is 1st sensor (on exhaust manifold) it is usually ~$30s on RockAuto.com You will need a special socket to remove it, but you can get it on loan in AdvanceAutoparts, Autozone, etc. I'd recommend Denso they a little bit more but worth it.
  12. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    I found it was more than 100$ for the upstream one. My father removed it, he didn't tell me anything about a special tool. I'll need to speak with him.
  13. Mendel Leisk
    42,293
    Canadian prices?
  14. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    No US.
  15. cyclopathic
    3,292
    547
    2014 Prius c
    Apologies. Just checked RockAuto and it is listed there for $109. Cheapest one is $93. The ones I've bought for other cars were fraction of that.
    Did not know they were so expensive for Gen3. Part # DENSO 234-9090, maybe you'll find it cheaper
    #35 cyclopathic, Aug 14, 2015
  16. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Just spoke with my father. He says there are 2 catalytic converters and he removed the sensor before those, but it was not that much close to the motor. He will have a second look once he comes here.
