Check Engine Light 25k Miles
Discussion in 'Gen 4 Prius Technical Discussion' started by Since2016Green, Jun 1, 2018.
  1. Since2016Green
    Since2016Green New Member
    Got a check engine light on a 2016 Prius two eco took it in to the dealership and got a code for the o2 sensor. Warranty is covering it but this particular dealership said they haven’t had a Prius with this issue.
    49,520
    not surprising they haven't seen it yet. usually for higher mile cars. maybe defective or installed incorrectly.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Most likely defective than installed incorrectly. If it was installed incorrectly, it would've been throwing codes the entire time when you were driving and not just after having gone 25k miles. I just hope they made those things easier to swap out than from previous generations because its a basic plug and play replacement item when its time to do so.
    RCO likes this.
